Anyting I should do while I have the trans removed? #723640 05/15/06 09:14 PM
Starchild Offline OP
With a good bit of help from Tad (Nazrat), I got most of the work done removing the transmission. The only thing left is 6 bellhousing bolts. I'll be replacing it with a freshly rebuilt 700R4 :knocks on wood:. Is there anything I should take care of on the engine while I have the trans pulled?
The engine is a SOHC with about 150k, and there seems to be a lot of oil on the trans housing, and the back of the engine. I'm going to clean everything up and see if I can locate a source, but I haven't had any real oil usage problems in the past.
I only want to do this once
Thanks,
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Anyting I should do while I have the trans removed? [Re: Starchild] #723641 05/15/06 09:34 PM
N
NotSoSimple Offline
If you have found oil back there, check the rear main seal. If it is leaking, change it out!
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: Anyting I should do while I have the trans removed? [Re: NotSoSimple] #723642 05/15/06 09:50 PM
The rear main seal was on my list of things to check <img src="/forums/images/graemlins/kewl.gif" alt="" /> I haven't messed with one of those yet, so I'll have to pull the manual and get a procedure.
Thanks,
Keep it coming
"SERENITY NOW!"
Re: Anyting I should do while I have the trans removed? [Re: Starchild] #723643 05/16/06 12:31 AM
JLEMOND Offline
ANDRE CHECK THE BACK SIDE OF THE CYL HEADS AND MAKE CERTAIN THAT THE CAM BORE PLUGS ARE NOT LEAKING AND THAT THE RETAINER PLATES ARE ON THE HEADS , IF YOU ARE GOING TO USE THE SOHC ENG THOSE PLATES ARE A MUST TO KEEP THE PLUGS FROM BLOWING OUT , THEY WERE ALL SUPPOSSED TO BE REPLACED ON ALL EARLY VEH BY A REALL MANY YEARS AGO BUT THERE WERE A FEW THAT SLIPPED THRU , IF THEY ARE NOT THERE LET ME KNOW I HAVE THE DIAGRAMS TO MAKE NEW ONES , I COULD TELL YOU WHO DESIGNED THE ORIGINAL ONES FOR THE SOHC BUT I WON,T ... LET ME KNOW JERRY
Re: Anyting I should do while I have the trans removed? [Re: JLEMOND] #723644 05/16/06 03:07 AM
I'll take a good look at things when I get the trans out. I'll take a picture to make sure.
Thanks Jerry <img src="/forums/images/graemlins/kewl.gif" alt="" />
"SERENITY NOW!"
Re: Anyting I should do while I have the trans removed? [Re: JLEMOND] #723645 05/16/06 08:01 PM
Smiley Offline
...THEY WERE ALL SUPPOSSED TO BE REPLACED ON ALL EARLY VEH BY A REALL MANY YEARS AGO BUT THERE WERE A FEW THAT SLIPPED THRU
Based on the amount of oil that I've seen toward the rear of my SOHC 3.2 lately, I'm guessing that mine probably didn't get those plates either.
So, Andre, ya wanna maybe make a few spares while you're at it? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Well... IF I HAD TO GUESS... <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Anyting I should do while I have the trans removed? [Re: Smiley] #723646 05/16/06 08:03 PM
barak Offline
Whil;e the tranny is out , if its been used , you might want to replace the seal rings on the shafts , and the filter.Saves a little work down the road <img src="/forums/images/graemlins/smile.gif" alt="" /> And definately change the rear seal while its there in front of you.
Re: Anyting I should do while I have the trans removed? [Re: Smiley] #723647 05/16/06 08:59 PM
If I end up having to make some retainer plates, I'll take good notes, and maybe make a few sets, depending on the complexity <img src="/forums/images/graemlins/kewl.gif" alt="" />
I've got a newly rebuilt trans to go back in.
Thanks guys
"SERENITY NOW!"
Re: Anyting I should do while I have the trans removed? [Re: Starchild] #723648 05/16/06 10:06 PM
Bansil Offline
Jerry If you can send me a copy of the diagrams,I'd appreciate it.I'd like to look at them.
Thanks
Oh and Andre,might be easier to replace all your heater hoses with new ones w/o the tranny in there.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Anyting I should do while I have the trans removed? [Re: Bansil] #723649 05/16/06 10:26 PM
And the list grows <img src="/forums/images/graemlins/pfft.gif" alt="" />
"SERENITY NOW!"
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6403 MB (Peak: 0.7659 MB) Data Comp: Off Server Time: 2026-11-02 08:02:24 UTC
