Pinion Flange #723796 05/16/06 07:41 AM
langforg Offline OP
What type of pinion flange is on an Isuzu 12-Bolt? I am curious because I am thinking of swapping one into my bronco 2. What do I need to be aware of when doing a swap like this. If the T-Case flange and the pinion flange are different, Can an adapter be made or even custom shafts? I am new axle swapping and don't really know a lot about these things. Thanks.
Brad
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: Pinion Flange [Re: langforg] #723797 05/16/06 01:07 PM
RobG Offline
if you want to swap a 12-bolt under your bronco, the easiest thing to do would be change the end of the bronco's stock driveshaft to attach to the isuzu yoke (which bolts to the 12-bolt flange). this yoke either accepts a 1310 std joint or the isuzu one (which is very close to std. toyota joint).
-Rob
Re: Pinion Flange [Re: RobG] #723798 05/16/06 09:22 PM
TrooperJ Offline
What axle is in the front of the pony? Can you get 4.56's (or 4.77's or 5.38s for that matter) for the front end to match the rear?
Otherwise, i would do what rob suggested, just getting a new driveshaft with the correct connections on there.
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: Pinion Flange [Re: TrooperJ] #723799 05/17/06 01:44 PM
RobG Offline
the front is a D44... so yes, you can get 4.56, 4.88, or 5.38's for it.
-Rob
Re: Pinion Flange [Re: RobG] #723800 05/17/06 05:40 PM
langforg Offline OP
Swapping into Bronco 2 so the front is a Dana 35 TTB. I still think gearing options are available.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6056 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-10-24 13:09:16 UTC
