Failed safety inspection...mystery light #724177 05/17/06 04:45 AM
rijrnnr Offline OP
'96 Trooper failed safety inspection due to burned out bulbs.
Simple, huh? Yeah, for you maybe. Unfortunately, I can't figure out where the switch is located so I can't test my new bulbs. In fact I don't even know the purpose of the light. It's the clear bezel just under the front turn signals and it doesn't come on with the headlights, parklights, or emergency flashers. Can somebody help me please, so I can get a sticker on this thing? Yep, I'm sober.
Re: Failed safety inspection...mystery light [Re: rijrnnr] #724178 05/17/06 06:56 AM
The light is there so that it illuminates whatever you are turning towards when you flick the turn signal on.
I'd say your wiring harness is shot, or something of the sort, if the new bulbs aren't working.
Re: Failed safety inspection...mystery light [Re: rijrnnr] #724179 05/18/06 12:11 AM
DieselBob Offline
Like Zillon said, It's there to light the area into which you are turning.
and it doesn't come on with the headlights, park lights, or emergency flashers.
You have to have the headlights on and the turn signal on to get them to light.
and
Maybe the safety inspector couldn't figure out how they operated either so they must be in violation. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Bob
"You can't expect to wield supreme executive power just 'cause some watery tart threw a sword at you."
02 Trooper S, TOD, Aisin Hubs, FJORD Blue, ARB 3444070 Winch Bar. Dueler A/T REVO LT265/75R16
Re: Failed safety inspection...mystery light [Re: DieselBob] #724180 05/18/06 12:56 AM
Z
zKnightWhoSaysNi Offline
and to qualify further... you cannot simply hold the turn signal on, as in lane changes, you must push the lever all the way until it engages and stays on for the side lamps to come on. (with the headlights on)
'99 Trooper, 912's
'89 Trooper RS, 2.6
Re: Failed safety inspection...mystery light [Re: zKnightWhoSaysNi] #724181 05/18/06 02:27 AM
rijrnnr Offline OP
I do not hesitate to thank you guys. As usual, this forum and it's members saved me a garage bill. The inspector was good..(the bulbs were bad), and I never thought to turn on the blinkers and headlights at the same time.
Thanks to all three of you first responders.
Re: Failed safety inspection...mystery light [Re: zKnightWhoSaysNi] #724182 05/22/06 12:35 AM
DieselBob Offline
KnightWhoSaysNi <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Bob
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6085 MB (Peak: 0.6786 MB) Data Comp: Off Server Time: 2026-07-13 14:31:52 UTC
