common failure modes on 1st gen 4runners? #724529 05/22/06 06:08 AM
F
fly_it_slow Offline OP
I'll be pulling my engine out for a rebuild and going through my very worn '87 and would like to beef up any and all common items that are known to fail under hard use. Could some of you experts suggest areas that need reinforcement or that commonly break with hard use?
Thanks.
Joa
Re: common failure modes on 1st gen 4runners? [Re: fly_it_slow] #724530 05/23/06 02:32 AM
chuckles Offline
From what I know, the head gaskets and timing chain assemblies are prone to failure. Look in the tech section for some helpful hints on 22RE rebuilds..
85 Runner. (Camo Beast)
Re: common failure modes on 1st gen 4runners? [Re: chuckles] #724531 05/23/06 08:39 PM
Seattlegti Offline
I've had to repair/replace quite a few things in the front steering/suspension due to lack of maintenance. Don't think the previuos owner had ever heard of a zert fitting.
CV boots, ball joints, steering knuckle,repack hubs,replace brake pads,shocks, bushings, etc. Nothing too difficult, just time consuming. Made a huge differenc in road feel though, I'd say worth it in the long run.
Might check it all out while the head is bieng machined.
Might as well drain a refill your diffs and trans while your already dirty.
Re: common failure modes on 1st gen 4runners? [Re: Seattlegti] #724532 05/24/06 04:02 AM
F
How about stuff that's actually broken with hard use? Including systems things that are common (power steering, alternator, etc)?
Thanks.
Joa
Re: common failure modes on 1st gen 4runners? [Re: fly_it_slow] #724533 05/24/06 04:32 AM
DRTDEVL Offline
Idler arm
Re: common failure modes on 1st gen 4runners? [Re: DRTDEVL] #724534 05/24/06 05:44 PM
Seattlegti Offline
Idler arm
Good call. I keep a spare in my truck box.
Re: common failure modes on 1st gen 4runners? [Re: fly_it_slow] #724535 06/01/06 03:29 AM
kewlynx Offline
Open up the wire harness for the fuel injectors and remove those butt splices and solder them instead.
Also send the injectors and the CS injector to www.witchhunter.com for reconditoning.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6178 MB (Peak: 0.6954 MB) Data Comp: Off Server Time: 2026-11-16 08:47:38 UTC
