A/C conversion #724757 05/22/06 10:37 PM
I have a 1990 Toyota 4Runner and my A/C just won't work anymore. Since it's on R-12 I have to convert it to a R-134A and I was wondering if anyone had any help on that? I already bought a little kit with the adapters and all, but I don't know if I need to flush the system or anything else. Any info would be great. thanks guys.
Re: A/C conversion #724758 05/22/06 11:59 PM
ldivinag Offline
you need to fully evacuate your R12 out of the system and into a "safe" place.
but i coulda sworn there was a new substitute and was 100% compat with R12.
much cheaper too...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: A/C conversion [Re: ldivinag] #724759 05/23/06 01:05 AM
Adam F Offline
Replace all the o-rings with green nitrile ones.
Make sure you use Ester synthetic oil. DO NOT USE PAG OR MINERAL OIL.
It will work best if you take it to a shop and have them pull a vacuum on it for a half hour or so. This will clean out the system of any contaminates.
97 4R, stock, daily driver
Re: A/C conversion [Re: Adam F] #724760 05/23/06 02:08 AM
chuckles Offline
Use HC12a. Much better. 34% more efficient than R12, and blows(no pun intended) R134a in the weeds.
http://www.coolearthinc.com/
or here:
http://www.autocool-refrigerants.com/product.htm#tech%20page
I'm converting my R12 85 4Runner to this this week..
It's compatible with both 12 and 134 systems..
85 Runner. (Camo Beast)
Re: A/C conversion [Re: chuckles] #724761 05/23/06 07:42 AM
so basically all you're saying is that if I switch to R-12A I don't have to do all the conversions that I would with the R-134A. Is that right? or would it just be as simple to retrofit the valves and put in R-134A, becasue I already have 3 cans of R-134A.
Re: A/C conversion #724762 05/23/06 08:00 AM
chuckles Offline
all you gotta do is evac r12 system to 0, then replace service ports with r134a ports, then add HC12a to system. That's it. and it will work 30% better then 134a in the same system. Plus no oil/dryer change, and head pressure is 50% lower on HC12a system and evap temps are 10-15 degrees colder.
Re: A/C conversion #724763 05/26/06 07:15 AM
larsdennert Offline
Hopefully you don't have a leak though or did it just slowly get worse over the years? How long has it been out of commish? Those seals might be pretty dry.
Re: A/C conversion #724764 05/30/06 06:43 AM
rick92 Offline
I just converted my 92 4runner a week and a half ago to 134a. My A/C was dead like yours and an R12 system. Here is what I did. Bought a new receiver/dryer, a package of green o-rings and a conversion kit that had three 15 oz bottles of 134a. Each bottle was 12 oz of 134a and 3 oz of Ester oil. I had this 4runner into Toyota 2 years ago on an expansion valve recall so I did not mess with changing it or the rings at the evaporator. I replaced the o-ring on the discharge line to the condenser, the two o-rings on the receiver/dryer and an o-ring on a connection to the lower left of the receiver. Basically, the four o-rings on the front of the 4runner. I borrowed a vacuum pump and set of gauges from a friend and pulled a vacuum on the system then let it sit for a hour to see if it held, and it did. Once I knew it did not have any leaks I let the vacuum run for about 30 or 40 minutes to purge the system. Charged the system up with 2 bottles of 134a and about 2 more oz from the third can for a total of 26 oz of 134a and 6 oz of oil. The system was blowing at 37 deg F when I stopped adding 134a. Not bad for an under a $100 convert. By the way I still have the same compressor and did not touch it. I did not feel like trying to pull it out and I thought if the system did not leak in the vacuum test why mess with it. Good luck.
Re: A/C conversion #724765 06/01/06 02:53 PM
fourwd1 Offline
When mine was out 2 years ago, an AC shop pulled vacum on it for almost an hour, found no leaks, removed the little R12 that was left, and filled it with R134 and some PAG oil.
He said Honda has sent out a service bulletin with those instructions and he's done over a hundred times with no come backs.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: A/C conversion #724766 06/13/06 04:55 AM
MisterZee Offline
i bought 'freeze 12' replacement from frosty-freeze on ebay, seemed like a good deal, and it works.
98 Taco 4WD
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6298 MB (Peak: 0.7369 MB) Data Comp: Off Server Time: 2026-11-17 11:03:26 UTC
