balljoint spacers #725352 05/24/06 04:33 PM
roadayo1 Offline OP
I tried a search but didnt come up with what I was looking for but I was wondering if anyone has made there own balljoint spacers. I was looking at them and thought that they would'nt be that hard to make or am I completely wrong.
Re: balljoint spacers [Re: roadayo1] #725353 05/24/06 05:13 PM
RobG Offline
don't expect much of a reply... you've basically hinted around your own answer... balljoint spacers aren't rocket science, so if you want to make a pair and have the means to do, certainly hop to it... there isn't really any advise or trade secrets for us to give. Basically what I'm saying is, its a simple enough fab project, no one's going to spoon feed it as we have vendors that support us and fill that gap with ready made products.
So, if you decide the hassle isn't worth your time, check out vendors like independent4x and darlinton offroad who have ready to go bolt-on solutions and aren't particularly expensive. I suggest you look there.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
-Rob
Re: balljoint spacers [Re: RobG] #725354 05/24/06 08:02 PM
randii Offline
Yup. It is do-able -- you just need the right plate, the right dimensions, the right drills, and a means of cutting the plate to size.
Randii
Re: balljoint spacers [Re: randii] #725355 05/25/06 05:41 AM
maxwell417 Offline
Yup ... I made my own out of 1/4" 6061 T6 aluminum. It was really easy. But I bought my second set from
INDEPENDENT4x
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: balljoint spacers [Re: randii] #725356 05/25/06 08:04 PM
2000Trooper Offline
I got mine from Independent4x also but if your going to build your own, are the original screws long enough? I know the one I bought came with longer screws.
Jaime
Re: balljoint spacers [Re: 2000Trooper] #725357 05/26/06 12:21 AM
Shorts Offline
No, you'll need longer bolts. So, you go to the hardware store and get the proper strength and proper length bolts.
Shorts
Frankly my dear...
'96 Isuzu Wizard 3.1TD
Re: balljoint spacers [Re: Shorts] #725358 05/26/06 12:37 AM
TrooperMark Offline
Ok...hoping to get a little help regarding the spacers. I just raised my 95 trooper up a total of 3 inches. In the process I flipped and spaced the balljoints. As a result, I'm having major positive camber issues over 2 degrees positive. Tech said he couldn't fit anymore shims. The tech was a younger guy and really impressed with the truck so I asked him if it would be ok to remove the spacers right there. We took the time and removed the spacers and then rechecked the alignment, this time it was almost in spec.
So gurus any insight??? I figure if the balljoint was at stock location, the camber would be dead on.
1995 Trooper LS (OME Coils & 2" spacer, Rancho 9000, Nitto Terra Grappler 34", K&N, ARB Snorkel, Calmini Rear Bumper) In garage (9000 winch, custom S. America winch bumper, Delta Cams, Tera-Low 3.07)
Re: balljoint spacers [Re: TrooperMark] #725359 05/26/06 12:44 AM
strawmyers Offline
Isuzu Moderator
Different trucks have different requirements. Its been discussed by others in the past that the spacers actually hindered their ability to align within specs. Other people have only been able to align within specs by using the spacers. As with most things Isuzu, its hit or miss <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6215 MB (Peak: 0.7210 MB) Data Comp: Off Server Time: 2026-06-20 17:52:59 UTC
