Rancho 9000's - Dial reference orientation? #725541 05/25/06 05:19 AM
RubyTrooper Offline OP
OK, I finally installed my Rancho 9000s! <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> However, now I am confused to what the setting is on the shocks. With reference to the image below:
Is the above shock adjusted to setting:
  • 5
  • 3
  • 1
  • 9
  • 7
  • Other
<img src="/forums/images/graemlins/confused.gif" alt="" /> Enlightenment would be appreciated, and, any tips on the settings that you have learned also are valued. <img src="/forums/images/graemlins/cheers.gif" alt="" /> TIA
Isuzu Trooper, '91, 2.8L, 3" PA BL, coil sprung SAS, OX locker front, Detroit back, 5.38 gears...
Ruby's got a theme song!!! Sing-a-long
Re: Rancho 9000's - Dial reference orientation? [Re: RubyTrooper] #725542 05/25/06 05:33 AM
Richard Saylor Offline
Someone correct me if I'm wrong (it's been a LONG time since I've had 9000s), but IIRC, if you spin the dial as far as it will go to the left, that's the first setting. All the way spun to the right would be the highest setting. I'm thinking you have it on the 5th setting there by the looks of it.
Hope that helps ...
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Rancho 9000's - Dial reference orientation? [Re: Richard Saylor] #725543 05/25/06 01:48 PM
CPOM Offline
Yeah, you can see the arrow by the "1".
CHRIS
98 Amigo, 92 Pup
Re: Rancho 9000's - Dial reference orientation? [Re: Richard Saylor] #725544 05/25/06 07:57 PM
2000Trooper Offline
Richard is correct, its set to level 5 in the picture.
Jaime
Re: Rancho 9000's - Dial reference orientation? [Re: RubyTrooper] #725545 05/25/06 09:29 PM
TrailMystic Offline
Now that you installed them, be sure to turn the dials through the full adjustment range at least every few months to keep rust from freezing up the adjuster. If you want to prevent rusting, take off the adjuster by removing the allen screws, fill the inside with lithium grease, and replace it. Water just gets in there and rusts things. Overall, I do like them and have make this part of regular maintenance. If they ever get stuck, take off the adjusters and give the inside surface a wack to free it up and then grease it.
My boots seem to get torn up after a year or so. Matt Indy4X sells new boots (different colors) for just a few bucks.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: Rancho 9000's - Dial reference orientation? [Re: TrailMystic] #725546 05/25/06 10:06 PM
Thanks for the tip! Yeah, they didn't get very rusty while in the closet for the last year and a half. <img src="/forums/images/graemlins/lol.gif" alt="" /> So, they are mounted now with the dial adjuster end at the bottom. If I remove the two allen bolts and the adjusters to grease the area will any oil pour out of the shock body? <img src="/forums/images/graemlins/scared.gif" alt="" />
And the obvious question that I forgot!! Is the highest setting, "9", the stiffest? That is, the most dampening is offered when the shock is set to "9"?
Re: Rancho 9000's - Dial reference orientation? [Re: RubyTrooper] #725547 05/26/06 08:39 PM
2000Trooper Offline
You are correct,
Here is quote from their web site: "9 firm for off-road and 1 is soft for street"
Jaime
Re: Rancho 9000's - Dial reference orientation? [Re: 2000Trooper] #725548 05/26/06 08:50 PM
barak Offline
You can always add on the controller.I have it , but haven't put it on yet.It replaces the dial on the shocks , then you just push a button in the cab to change the settings. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6237 MB (Peak: 0.7235 MB) Data Comp: Off Server Time: 2026-06-07 11:24:55 UTC
