Replacement Transmission #726942 05/25/06 06:21 PM
P
parshal Offline OP
I've got an '83 pickup that is not going into gear (any gear). I'm going to pull the tranmission and look at the clutch but figure I should have a lead on a tranny just in case. I've got a friend with an '84/85 transmission he'll sell me fairly cheap. What year transmissions will fit in an '83 with no modification? I'm assuming '83 and earlier.
Re: Replacement Transmission [Re: parshal] #726943 05/25/06 06:35 PM
justinmnhall Offline
you might check the master cluch cyl. and line first. It might just be a simple leak or something, if it is then you just saved alot of time. If not then you wasted 5 mins.
87 ex-cab 4x4 D D
89 4runner Work in progress!
Re: Replacement Transmission [Re: parshal] #726944 05/25/06 07:38 PM
Red_Chili Offline
Toyota Section Staffer
Check Marlin's site, even shoot him a call. I believe you need an L series, not the best tranny Toyota has ever used, but can be serviceable if properly overhauled.
-Bill
Re: Replacement Transmission [Re: justinmnhall] #726945 05/25/06 08:26 PM
P
parshal Offline OP
I already replaced the master and slave cylinders and the problem is still there. I was hoping for simple but this things cost me since I got it so why should this be different?
I'll give Marlin a call and see what's up. Good idea. Thanks.
Re: Replacement Transmission [Re: parshal] #726946 05/25/06 09:28 PM
P
parshal Offline OP
Does anyone know if an '83 transmission from a 2wd can be used in an '83 4wd?
Re: Replacement Transmission [Re: parshal] #726947 05/25/06 09:43 PM
I think the output for a 2wd goes to a drive line so no fitting for a transfer case. for a temp. solution you might be able to use a 2wd drive line and 2wd transmission(if you don't need 4wd right now)
87 ex-cab 4x4 D D
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6081 MB (Peak: 0.6772 MB) Data Comp: Off Server Time: 2026-06-10 06:32:09 UTC
