Pulley removal #727229 05/26/06 05:36 PM
Are the nuts for the main pulley reversed thread or normal lefty loosey? I've been out there trying to break the thing loose for 30 minutes and used halfa can of pb blaster and all Ive done is rolled the thing up onto my blocks.
My haynes manual says nothing about them being reversed but I figured I'd check here just to make sure.
Re: Pulley removal #727230 05/26/06 06:16 PM
Richard Saylor Offline
I don't know for sure (hopefully someone will chime in that does) but I don't think they're reverse thread. Of all the motors I've done, none have been reverse thread (but that's not to say there aren't any). Have you tried the breaker bar on the frame trick? Put the breaker bar onto the frame, then TAP the starter. That usually does the trick.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Pulley removal #727231 05/26/06 06:29 PM
Mike Bridges Offline
It's counter clockwise, If you have an impact it will make it easier.
Re: Pulley removal #727232 05/26/06 07:35 PM
A
acy76 Offline
Not to sound patronizing, but you have taken steps to lock the pulley in place while trying to loosen the bolt, right? Otherwise you'll never get it loose.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: Pulley removal [Re: acy76] #727233 05/26/06 08:06 PM
FSJ1978 Offline
Another trick is to put a breaker bar on it, set the handle up against something solid like the frame, and bump the starter.
Chris Enos (Chino, CA)
'91 Isuzu Amigo "Rover" (Camaro 3800 swap in progress / 2.25" exhaust)
....(SOA / Custom rear bumper / CB / HAM)
Re: Pulley removal [Re: FSJ1978] #727234 05/29/06 04:46 AM
8
800XL Offline
I've done several of these, and only one was I able to get it loose without using the starter. You can try sticking in the highest gear (4th or 5th) and having someone stand on the brakes, that worked for me once.
The starter trick really works well, just be careful what you brace your breaker bar against, make sure it is against the frame and not near any lines. On my 86 the power steering lines were close. Just give it a blip on the starter, it should break right loose. The only one I had to really hit over and over, I finally got with a brand new Optima RedTop battery.
"Time and tide melts the snowman"
Re: Pulley removal [Re: 800XL] #727235 05/29/06 03:19 PM
A
acy76 Offline
I've had good luck holding pulleys using a Harbor Freight chain wrench I bought for around $9. It looks like a vise-grip but with a length of chain on it that can be made into a loop. I use a piece of old v-belt so it doesn't cut into the pulley (or cam gear, etc. -- I've used it there, too, with great results, just used a piece of timing belt to protect the gear). You can then slide a length of pipe over the end and get a lot of leverage on the pulley.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6136 MB (Peak: 0.6911 MB) Data Comp: Off Server Time: 2026-11-02 07:43:14 UTC
