AC Condensation Leak #727263 05/27/06 12:02 AM
Curran Offline OP
It just got hot enough to start using the AC today. After a few minutes of nice cold air flowing into the cab, water started driping from the cooling unit into the passenger floorboard. Is there a condensation drain hose that could have come loose or clogged? If so, where can I find it?
1990 4x4 xtra cab 4x4, 22RE, 5-Speed...
Thanks,
Curran
Re: AC Condensation Leak [Re: Curran] #727264 05/27/06 12:15 AM
Kona Offline
You should be able to see the hose on the bottom of the evaporator core that runs through the firewall. The evap is in front of the glove box just left of center. You should be able to see the hose without pulling the glovebox(I think).
Back in the West!
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.5872 MB (Peak: 0.6350 MB) Data Comp: Off Server Time: 2026-11-18 22:35:41 UTC
