new problem... starting #727526 05/28/06 06:22 AM
A
Azo Offline OP
ok my truck ran fine the only thing that was wrong with it was the battery/charge light was on so i replaced the altanator and wow the lights were gone who would have know.. but right after replacing the alt i have a bad idle and wants to die sometimes... so i decided to replace the wires thinking that would help but now it wont even start and it just makes the horable clicking noise.. i have replaced the start and it would turn over finaly but after a few min the start starts to click once again... i checked and changed the batter allready but that is not working.. tryed a battery jump pack and charger too
so my problem is what could have happend??
and is my plugs in the right order? 1324???
85' Pickup, Crossover steering, 33x12.5 A/T, 4" lift
Re: new problem... starting [Re: Azo] #727527 05/28/06 06:34 AM
kewlynx Offline
holyrunonsentencebatman!
Did you get the 'new' alternator checked before you stuck it in there? <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" /> You didn't say where that one came from...
Check your connections again, fuses, etc.
**ubi apis- ibi salus**
Re: new problem... starting [Re: kewlynx] #727528 05/28/06 07:06 AM
2ndGenToyotaFan Offline
Hook a jumper wire to where the small wire plugs into the starter (aligator clips work well) and put the other end to the + batery. If it starts you have a problem in your wiring, relay, or ignition switch.
Jerod
89 4Runner, 282k miles. "I gotta have more cow bell"
Re: new problem... starting [Re: 2ndGenToyotaFan] #727529 05/28/06 02:26 PM
4Crawler Offline
Re: new problem... starting [Re: 4Crawler] #727530 05/29/06 04:06 PM
Paul Elbisser Offline
Another thing to try is a new batery terminal. I had minego bad on me. The steel stud starts to carode inside the lead terminal. I rebuilt a starter and still had the prooblem. Then one day whil disconecting my batery it finaly broke off. Starts great now. But I did have to change the alternator last week. Diods went out. Not sure if it is related or not.
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: new problem... starting [Re: Paul Elbisser] #727531 05/31/06 01:54 AM
Jeffstoyo Offline
Firing order is 1342
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6129 MB (Peak: 0.6833 MB) Data Comp: Off Server Time: 2026-06-17 13:25:45 UTC
