7/16" head bolt #727574 05/28/06 08:32 PM
burtv Offline OP
I am doing a 4.0 head conversion and my 1983 258 (4.2L) engine uses 7/16 inch bolts. The 4.0 head uses 1/2 inch bolts. Does anyone know where I can purchase 7/16 head bolts with sleeves to fit in 4.0 head conversion? Or do you know if the engine block can be machined to 1/2 inch holes while the engine is still in the Jeep?
78 CJ7, 83 wide track axles/Dana 30 Front W/ OX Locker, Model 20 rear w/ one piece shafts(welded tubes)/Detroit Locker, 4.10 gears. 4.5" spring lift with 3/4" shackle lift. 35x12.50 BFG MT, 4.2L, Weber Carb, K&N, T18,Scout Dana 300,Warn 9.5ti
Re: 7/16" head bolt [Re: burtv] #727575 05/28/06 09:00 PM
JeePete Offline
The 7/16 head bolts you have will work just fine. You don't need to do any drilling on the block either. You have several options. I used a head made for 1/2" head bolts with 7/16 bolts for years and never had a problem. I didn't realise the discrepancy until I did my 4.0 head swap. What I did then was buy a set of spacers from Mustang Warehouse because they had the best price I could find at the time. If I were doing it again, I would get just 4 spacers from Summit Racing and saved some money. That is all you need. Two would be enbough to position the head, once it's torqued down it's not going anywhere. You could even use some tape on a couple of bolts instead. Like I said, I used nothing before and had no problems, maybe I'm just lucky though. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5874 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-06-10 01:40:34 UTC
