Steering Wheel play #727825 05/30/06 05:45 AM
jsanch Offline OP
Hi guys. Have a problem with my wife's 89 4runner. I rarely use it, but this is not the problem. I drove it the other day and the handling is terrible. The truck seems to wander all over the place, it has alot of steering wheel play. What can be the problem, you guys that have more savvy about steering linkages, etc.? How can I diagnose the problem? Thanks in advance
1987 Raider - auto, Weber carb, bouncy seat, 31 Coopers,
1989 4Runner 4 Cylinder All stock
Re: Steering Wheel play [Re: jsanch] #727826 05/30/06 06:37 AM
kewlynx Offline
Read this article to see if that fits the bill for what you're experiencing.
Also inspect the ball joints and tie rods. If those tie rods go, you will NOT be able to control the vehicle; all three components are easy enough to change yourself.
**ubi apis- ibi salus**
Re: Steering Wheel play [Re: kewlynx] #727827 05/31/06 06:28 AM
jsanch Offline OP
Thanks, I was going to check the idler arm the first chance I get which is during the weekend
Re: Steering Wheel play [Re: jsanch] #727828 06/04/06 02:53 AM
TRDSR5 Offline
There's also a gear-slop-taker-upper adjustment you can make on top of the steering gear box (pert near everything japanese has this adjustment)
There is a stud with a slot in the top and a jamnut on top of the steering gear box. Lossen the jamb nut while holding the position of the stud intact. Turn the stud clockwise (driving it further into gear box) and retighten jamb nut.
I find it best to get most of the weight off the front tires first, not all but most, so that steering effort is very light. Go slow, maybe half a turn at atime then recheck steering wheel play. I turn steering wheel while eyeballing movement of the front tires.
Over adjusting slop stud doohickey is bad. Be gentle Grasshoppah.
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6035 MB (Peak: 0.6588 MB) Data Comp: Off Server Time: 2026-06-17 10:47:02 UTC
