Re: sudden overheat issue [Re: Bigpoppax2] #727992 06/07/06 08:07 PM
pinoy99 Offline
You have to remove the intake manifold. The thermostat housing is under the aluminum manifold.
Joe
The thermostat is in the area under the manifold but one can remove the thermostat without touching the manifold.
Re: sudden overheat issue [Re: pinoy99] #727993 06/15/06 08:47 PM
Bigpoppax2 Offline
I can say that on the 98 and up there is no way possible to change the thermostat without removing the intake manifold.
It is however possible to do on the SOHC engines.
Joe
Re: sudden overheat issue [Re: Bigpoppax2] #727994 06/16/06 01:21 PM
A
anubis Offline OP
I am going for a tuarus fan install to try and resolve the issue. Id like to pull the fan off so that I have more room. I havent even got to that. I am going to build the shroud after I get back from vaction in a week. I have ordered the aluminum alreadya dn have the fan so I am half way there.
I think it will take care of my problem.
BTW this has not happened again but I am concerned that it will this summer, on the beach or on a long hill climb that it will be.
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: sudden overheat issue [Re: anubis] #727995 06/19/06 10:26 AM
Bansil Offline
trust me on this,spend the time and just drop the radiator.
This weekend was the test,and from thursday to sunday the temp gage never went above normal and this included rough slow climbs a mile and such up mountains etc.
I never would of rushed the B/L install if I would of know what a difference the radiator drop would make.
Now if the taurus fan/shroud etc. fits the radiator then go for that but the radiator drop is basically a free mod,just lot's of work.
bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: sudden overheat issue [Re: Bansil] #727996 06/19/06 03:28 PM
m_a_b Offline
I'll agree with Bansil on that one. I had a Nissan that I did a BL on and luckily, the lift came with the radator drop bracket. I never had any problems with overheating.
The bracket itself was pretty simple, but cutting the old one off was a pain, so a lot of people didn't do it and just removed the fan shroud - they overheated a lot.
If your fan isn't in a shroud, then it isn't pulling air across the radiator. It takes the "easiest route" which is AROUND the radiator.
'99 Isuzu Amigo S, 3.2L 4x4 softtop, 3" Calmini Lift, Indy4x Custom Bumpers & Sliders
Re: sudden overheat issue [Re: Bigpoppax2] #727997 06/19/06 10:15 PM
NATO308 Offline
Joe
It can be done, just need 1/4" universal socket, 3/8" universal socket, long 1/4" and 3/8" extensions and lots of patience. Not just universal joint extensions but universal joint sockets. Did it on my 2000 Amigo without pulling the intake. Have to be able to work with mirrors and in the blind by touch for the most part.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: sudden overheat issue [Re: NATO308] #727998 06/20/06 02:58 PM
Bigpoppax2 Offline
I'd love to know how you got to the frontmost divers side bolt that's directly under the heater hose hard line. I had to remove it to get the that particular fastener even with the intake off.
And how in the hell did you get the bolts started back?? You must have a six pack of double jointed midgets working for you.
Joe
Re: sudden overheat issue [Re: Bigpoppax2] #727999 06/21/06 01:45 PM
Bigpoppax2 Offline
Ok I decided to snap a pic last night to show what I was trying to describe. Here is what I was talking about with the front most drivers side bolt being next to impossible to get to even with the intake off.
If you did that job with the intake on kudos, you are a better man than I. I'd suggest to most that the intake should come off if nothing else to replace the o-ring seals in the heater hoses. Mine came off in pieces, I assume where they have put up with extreme temps for 100,000 miles.
Joe
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6296 MB (Peak: 0.7418 MB) Data Comp: Off Server Time: 2026-07-09 22:20:08 UTC
