choosing a transmission #728252 06/01/06 06:18 AM
79Toy4x4 Offline OP
I have a 1979 4x4 short bed with the stock manuel 4 speed thats days are numbered and want to trade it for a newer 5 speed manuel. Anyone know what year toyota tranny that would be the best to use? 4.38 diffs 20/22r hybrid. thanx
Re: choosing a transmission [Re: 79Toy4x4] #728253 06/01/06 06:20 AM
kyle-22r Offline
the "easiest" swap would be an L50 or L52. they are the 5 speeds found in '81-83 4x4s, and are the same length as your L43. the only mod you have to do is enlarge the hole in the floor. you'll need to grab the clutch set for the truck you pull it from, the slave cylinder, clutch hub and fork.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: choosing a transmission [Re: kyle-22r] #728254 06/01/06 06:31 AM
79Toy4x4 Offline OP
thanx, there are a couple junk yards in my area with a few toyota 4x4's just wanted to get an opinion before i go buy one. do you think the 1st gear ratio will be about the same in 4low? the stock 79 was just were i wanted it for crawlin
Re: choosing a transmission [Re: 79Toy4x4] #728255 06/01/06 06:35 AM
kewlynx Offline
http://www.4x4wire.com/toyota/faq/parts/
Scroll down. I also think Marlincrawler has the ratio information on his site for the early trannies as well.
Good luck!
**ubi apis- ibi salus**
Re: choosing a transmission [Re: kewlynx] #728256 06/02/06 02:21 AM
Jeffstoyo Offline
If you plan on lifting your truck much, you might want to consider upgrading to the newer 5-speeds (84-up). They are about 6" longer and allow for a longer front driveline. I have installed alot of these and they are a very simple install if you have a shortbed, if not, you will need to have some drivelines either modified or custom ones made. If you have a shortbed, you can just use the drivelines from the donor shortbed truck or any 4Runner. You then rotate your crossmember 180 on a verticle plane and redrill one hole on each side where the old front hole lines up in the center of the frame. Drill a 1/2" hole through the frame and install a 6" 1/2-13 bolt. You will end up with only 3 bolts per side if you use this method, but I have not had any issues with this.
If you have any questions, feel free to ask.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: choosing a transmission [Re: Jeffstoyo] #728257 06/02/06 03:14 AM
79Toy4x4 Offline OP
don't think i'm going to lift it at all. how it is right now I have been able to 4-wheel without too much problems in clearance. it sees more of steep inclines and ditches/ ruts than huge obsticals. I mostly find old trails behind long barn through the forrest and this truck goes over what ever I have come across so far. plus I dont like the body roll on lifted trucks. been in one that rolled. Isn't fun. thanx though.
Re: choosing a transmission [Re: 79Toy4x4] #728258 06/02/06 03:35 AM
Jeffstoyo Offline
They are still a good upgrade. Better bearings and all.
Good luck.
Jeff
It's all good!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6173 MB (Peak: 0.6960 MB) Data Comp: Off Server Time: 2026-06-10 01:32:23 UTC
