4.0 Head Conversion, Which Header? #728270 06/01/06 03:40 PM
burtv Offline OP
I am doing a 4.0 Head conversion and need to install a new manifold/header. They sure can be expensive. Here is a link to an OE replacement manifold. Has anyone used this? Its very similar to Borla, Thorley, Banks, etc. Was there performance gain? What headers have you had good luck with?
Link- http://www.autopn.com/store/pc/viewprd.asp?idProduct=20009
78 CJ7, 83 wide track axles/Dana 30 Front W/ OX Locker, Model 20 rear w/ one piece shafts(welded tubes)/Detroit Locker, 4.10 gears. 4.5" spring lift with 3/4" shackle lift. 35x12.50 BFG MT, 4.2L, Weber Carb, K&N, T18,Scout Dana 300,Warn 9.5ti
Re: 4.0 Head Conversion, Which Header? [Re: burtv] #728271 06/01/06 05:35 PM
A stock exhaust manifold is very different than a performance header. You need to buy one of the 300-400$ borla or gibson headers before you will notice any power, and it won't be more than 7-9 HP.
Re: 4.0 Head Conversion, Which Header? #728272 06/01/06 06:31 PM
BigJim Offline
Yep! What Sunder said.
Re: 4.0 Head Conversion, Which Header? [Re: BigJim] #728273 06/01/06 08:39 PM
burtv Offline OP
I could not agree more that stock exhaust manifolds are much different than performance headers and to take it a bit further stock manifolds alone run the gamit of different levels of realized performance enhancements. But what I was looking for was an opionion of the exhaust header/manifold that I had linked to and the other types of header/manifolds such as Borla, Thorly, Banks etc. Here are few more links, see the resemblance? Any change in your opinion? Do you think the header at Auto Parts Network is a good deal for the performance vs. $$ ?
Thanks.
http://www.prostreetonline.com/buy/borla%5Fexhaust%5Fheader/jeep/
http://www.rocky-road.com/xjthorley.html
http://www.bankspower.com/System.cfm?appid=AJ01&sysid=SJ01
Re: 4.0 Head Conversion, Which Header? [Re: burtv] #728274 06/01/06 10:09 PM
BigJim Offline
I would go for the Banks if I had the money! Stainless and has a solid bar to help hold the pipes in place when expanding and contracting.
The Tocky Road one has something near the banks. But this feature only MIGHT keep the manifold from leaking at the head.
As far as which will develope more horsepower? I doubt in normal driving you could tell the difference. On the strip you might find 6' between them in a 1/4 mile.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6068 MB (Peak: 0.6675 MB) Data Comp: Off Server Time: 2026-06-21 12:17:17 UTC
