steering column bearing again????? Help #728557 06/02/06 03:10 PM
3
3esso Offline OP
Last night while I was out cruising in my ride suddenly I felt the steering wheel kinda lose and moving side to side and up & down. like it was going to come off
Last time it acted like this was no longer that 9 months ago where I took it to a mechanic and he replaced the upper bearing in the column and every thing went back to normal. But yesterday the problem came back again?? could the bearing go bad in less than 1 year???? Or the mechanic did a really bad job??
I neead to know if the bearing is really the problem not somthing else causeing the bearing to go bad in such short time??
I hope it is not a big job because soon I will have to do the stem valve seals and it isvery costy
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Re: steering column bearing again????? Help [Re: 3esso] #728558 06/02/06 05:03 PM
JAVYPRO Offline
Or maybe the bearing came out of place due to age and what the mechanic did was place the bearing back in place and re-packed it without replacing it <img src="/forums/images/graemlins/scared.gif" alt="" /> . Do it yourself, it can be that hard, it just require very simple tools. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: steering column bearing again????? Help [Re: JAVYPRO] #728559 06/02/06 10:13 PM
DougH Offline
Mitsubishi Forum Moderator
Sounds more like the "saftey fuses" that connect the tilt assembly broke.
Mine did on the trail on my old truck. I just tack welded the assembly to its mount. Not as safe but they should still fail if I ever smash into it.
DougH
1995 SR - RIP
1993 RS - RIP
Re: steering column bearing again????? Help [Re: JAVYPRO] #728560 06/04/06 12:06 AM
3
3esso Offline OP
Is it really possible that the bearing just come off it place?????????? Because it happened suddenly not gradually
if so then I will have an unfinished business with my mechanic <img src="/forums/images/graemlins/shiner.gif" alt="" />
and about doing it my self, I think it is a bit complicated to me, cause I am by no means a mechanic althogh a have a bit of expereince.
Re: steering column bearing again????? Help [Re: DougH] #728561 06/04/06 12:10 AM
3
3esso Offline OP
There is nothing wronge with the tilt assemblly. the steering wheel just moves fron the top
Re: steering column bearing again????? Help [Re: 3esso] #728562 06/04/06 01:21 PM
DougH Offline
I guess you have it figured out then. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6105 MB (Peak: 0.6807 MB) Data Comp: Off Server Time: 2026-06-07 04:21:37 UTC
