How to remove 3rd gen limited flare/molding? #66471 06/17/03 10:05 PM
cronustrd Offline OP
I need to transfer the silver molding and flare from the rear passenger door of a 3rd gen 4runner to another door. How is it held on and how do I remove it? It is my bro's 4runner so i don't have it to look at.
Is it held on by clips/screws/double sided tape?
2000 Toyota Tacoma TRD: 5" and 35s, Winch, Snorkle, Custom Sliders/Bumpers, Dana 44 and dual cases in the werkz...
1988 4runner: Formula Toy Meat...Got Sawzall?
Re: How to remove 3rd gen limited flare/molding? #66472 06/18/03 09:57 PM
bump
Re: How to remove 3rd gen limited flare/molding? #66473 06/19/03 12:30 AM
I had a honda back in the day and I removed the molding on th efenders with a heat gun, then adhesive remover for the leftover goo. I think that would be how to get the strip off between the flare and the body panel. As for the flare itself, i dont know. I think they are just bolted on though. Why are you taking them off?
Re: How to remove 3rd gen limited flare/molding? #66474 06/19/03 12:37 AM
the original Door has a hole in it from a lawnmower launching a rock, and i have another door of the same color, but it doesn't have the molding on it. So i just want to transfer the molding to the new door.
I could of sworn i red somewhere that they are in via clips and holes, but i dunno.
any one else have any other ideas?
Re: How to remove 3rd gen limited flare/molding? #66475 06/19/03 01:47 AM
FattyCBR Offline
I know the molding above the running boards is held on by screws at the bottom and clips at the top. So I'd look at the bottom of the door to see. The only problem I can think of is that there is an adhesive strip that you will need to buy from the dealer for the new door.
If you search back a year or so there is someone on here who took out their rear molding and they had pics up of how it was attached.
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
Re: How to remove 3rd gen limited flare/molding? #66476 06/19/03 03:51 AM
Jeff the marmot Offline
Just drive on some really hard trails off-road. Rocks take them off pretty easily. <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> But they've never totally fallen off (yet) so I haven't seen the whole story to how they're attached. But it's mostly several clips in holes. I've seen at least 2 types of clips on these things. AFAIK, the obvious ones on the rear doors should pull straight out. I can't get some of the clips to stay clipped again, though. You might need to get a little creative when adding them to a door that didn't have the holes previously. I know JadeRunner added a sheet metal screw or two to the flares on the doors so it's not loose.
<img src="http://www.trailseeker.com/4x4/moabzuVI/Pritchett/marmot/images/marmot%20123.jpg" alt=" - " />
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.011s Queries: 14 (0.008s) Memory: 0.6114 MB (Peak: 0.6798 MB) Data Comp: Off Server Time: 2026-11-17 11:25:35 UTC
