Diagnostic Scanner Recommendations #728577 06/02/06 06:42 PM
bbusbee Offline OP
Can anyone recommend a decent diagnostic scanner that I could use for my Rodeo, Trooper and Mazda Millenia?
Re: Diagnostic Scanner Recommendations [Re: bbusbee] #728578 06/02/06 10:03 PM
Happy Birthday Richard Saylor Offline
What years? Are they all OBD II?
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Diagnostic Scanner Recommendations [Re: Richard Saylor] #728579 06/02/06 10:35 PM
bbusbee Offline OP
I have a 91 Rodeo, 97 Trooper and 99 Mazda Millenia. I'm told I need a OBD1 for the 91 Rodeo and OBD2 for the Trooper and Mazda.
Re: Diagnostic Scanner Recommendations [Re: bbusbee] #728580 06/02/06 10:47 PM
Yep, that's correct in that the 91 is OBD I and the 97 and 99 are OBD II.
There is no scanner needed for the 91. There's a jumper (under driver's kick panel, I believe) that you hook up with the key off. Then you turn the key to the on position, but do not start it. The check engine light will flash code 12 (1 longer flash followed by 2 shorter flashes) 3 times saying that it's in diagnostic mode, then it fill show any codes that are stored, then repeat the whole loop. Then you turn the key off and unhook the wires when done.
For the 97 and 99, you will have to have an OBD II scanner. My dad bought one from Autozone a while back and it's done what we've needed and isn't too bad. I believe it was a Sun (?) manufacturing product. The other that I've personally used was I believe an Auto X-Ray (?) unit. I used that when I worked for O'Reilly's. It's a pretty decent product, though a little pricey (at least for me) if you're going to buy it. It was about $200 and up.
84 Honda XL185S
Re: Diagnostic Scanner Recommendations [Re: Richard Saylor] #728581 06/02/06 11:23 PM
CPOM Offline
You can still retrieve info from an OBD I system. Do a google search for win aldl. He might be looking for more than just stored trouble codes.
CHRIS
98 Amigo, 92 Pup
Re: Diagnostic Scanner Recommendations [Re: CPOM] #728582 06/03/06 03:41 AM
Please 'splain the location of the jumper wire again, slower and in a way a dim bulb like me can understand please. <img src="/forums/images/graemlins/sleeping.gif" alt="" />
Re: Diagnostic Scanner Recommendations #728583 06/03/06 03:45 AM
W
Wareagle Offline
I like the Actron model cp9135. You can get one on e-bay for about $80. I have a cp9125. Its more limited in display functions, but sells for $50 on e-bay.
Re: Diagnostic Scanner Recommendations #728584 06/03/06 03:53 AM
On the Pickups, Rodeos, and Amigos, it's behind the driver side kick panel.
On the 1st Gen Troopers, at least the v6 (not sure on 4 cylinders), are under the center console.
On the 2.6L's, there's a 2 wires you hook together to throw the computer into diagnostic mode.
On the 2.8L's (3.1's as well?), there's an ALDL (I believe that's what it's called) connector that you have to jumper the upper right 2 pins with a wire to throw it into diagnostic mode.
3.2's? I have no idea on how they do it to be honest. Haven't seen them, so I don't know for sure. Maybe someone who knows will chime in.
I know Chris has a picture somewhere on here that shows the connector for the Pickups, Rodeos, and Amigos. I'll see if I can find that and link to it ...
84 Honda XL185S
Re: Diagnostic Scanner Recommendations [Re: Richard Saylor] #728585 06/03/06 03:57 AM
I found it. Wasn't too long ago posted either.
84 Honda XL185S
Re: Diagnostic Scanner Recommendations [Re: Richard Saylor] #728586 06/05/06 06:02 PM
smd94trooper Offline
at least for my Trooper there is a plastic plug that isn't plugged into anything that is where your right shin is when you're sitting in the driver's seat. What I did was I got a paper clip and, with the key 'off', I inserted it into the two most outside receptors on this plug. Then turned the key to the 'acc' mode(without cranking/starting the engine) and then the CE light will blink so many times. For example if it blinks 'blink'...'blink'...'blink'...'pause'...'blink'...'blink' that means code 32. HTH.
Stefan Doerr
'94 Trooper LS
6.5" lift, 33's, G80 and other stuff
http://community.webshots.com/user/smd94trooper
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6343 MB (Peak: 0.7427 MB) Data Comp: Off Server Time: 2026-06-17 06:50:21 UTC
