Automatic to 5speed swap questions #728785 06/04/06 02:55 AM
4
4x4yotaman Offline OP
I am in the process of swaping the motor and 5speed transmission from a rusted out 86 turbo pickup into my 87 turbo 4runner with an auto. Everthing is going alright so far but im not sure what i should do about the neutral/park safety switch/sensor. If anyone could give me advice about tricking the sensor so the my 4runner will start up that would be great.
1985 4runner
Re: Automatic to 5speed swap questions [Re: 4x4yotaman] #728786 06/04/06 03:43 AM
Snowtoy Offline
If you have the ecu from the turbo truck, you should swap it as well, then you wouldn't have to worry about the neutral/park safety switch/sensor.
Re: Automatic to 5speed swap questions [Re: Snowtoy] #728787 06/04/06 06:08 AM
matts Offline
If he wants to swap in the new (used) ECU will he have to swap wiring harnesses as well? If so that would be pretty drastic.
I'm pretty sure it's fairly easy to run a manual tranny in a 4runner wired for an automatic. I've been studying the issue because I have a wiring harness and ECU from an auto tranny 4runner that I want to install in my carbureted, manual trans '84 to upgrade it to EFI.
A lot of people on the Marlin Crawler board have done the tranny swap and they say it's a 'piece of cake'. Here's a Marlin thread on that topic -- Matt Tranny Swap Thread
Re: Automatic to 5speed swap questions [Re: matts] #728788 06/04/06 08:29 AM
4
Thanks for the link, just the info i needed. Looks like I should connect the black and white wires together from the white connector, seal up the blue one, and hopefully i get her runnin tomorrow. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1985 4runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-05-29 21:08:13 UTC
