Transmission Problems! #728816 06/04/06 05:21 AM
Macdaddy4738 Offline OP
Ive had my jeep about 2-3 months now, and it has performed flawlessly! Until today that is...
Second Gear has taken it upon its self to randomly pop out of gear at any time...
WHY is this? and what is the fix?
Re: Transmission Problems! [Re: Macdaddy4738] #728817 06/04/06 04:15 PM
JeePete Offline
It may help if you say what kind of Jeep and which type and model transmission you are talking about. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Transmission Problems! [Re: Macdaddy4738] #728818 06/04/06 05:58 PM
Possibly worn engagement teeth?? Does it grind? Do you have body lift?
Re: Transmission Problems! #728819 06/05/06 09:09 PM
its a 98 Jeep TJ, 5 speed transmission.
No body lift, no grinding, it just pops out, no real reason as to why.
Re: Transmission Problems! [Re: Macdaddy4738] #728820 06/06/06 04:25 AM
Unless there is something hitting the shifter, it's probably internal damage. Check out the shifter boot, ETC...
Re: Transmission Problems! #728821 06/06/06 08:00 AM
yea i popped it off and everything, didnt see anything preventing it from staying in <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Transmission Problems! [Re: Macdaddy4738] #728822 06/06/06 04:14 PM
It's probably internal damage then... Try changing the fluid.
Re: Transmission Problems! #728823 06/06/06 08:32 PM
Taddaaa, it WAS the shiter boot. I popped it off, but put it back on. After I took it off and left it off, it worked fine <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6116 MB (Peak: 0.6918 MB) Data Comp: Off Server Time: 2026-07-13 03:40:56 UTC
