Re: help my truck run cooler!! [Re: sdsnowman] #728930 06/06/06 01:03 AM
J94_4runner Offline
some toyotas came stock with them. my '94 v6 4runner for example had the engine driven main fan, and a electric condensor fan infront of the condensor. You can get a universl 12"? (small) electric fan, set it up for pushing and put it front of the condensor. but like I said, i'm running a SHO electric fan and removed my condensor fan (it broke) and have no overheating issue. today I drove over an hour in rush hour tampa traffic in high 90'sF and my A/c blew cold the whole time, and my engine temp gague didn't even flinch.
www.celicasupra.com
Re: help my truck run cooler!! [Re: J94_4runner] #728931 06/06/06 01:21 AM
sdsnowman Offline OP
sounds good- can you post the link for the sho fan? i know ive seen it before, but im bad at finding links and such.
thanks.
Re: help my truck run cooler!! [Re: sdsnowman] #728932 06/06/06 02:15 AM
in my Jeep i run that water wetter stuff made by red line and it dropped my temps by about 5 degrees
Re: help my truck run cooler!! [Re: sdsnowman] #728933 06/06/06 05:35 AM
DirtCheap Offline
I, also use "Wetter Water" by Redline and noticed a drop in tempature.
1989 Toyota SR5 DLX SB
1995 Toy DX XTRA Cab 4x4
1989 Dodge Raider 3.0 V6, 5 spd, Michelin LTX series, bouncey seat
1988 Dodge Raider A/T w/Offroad Package
1959 Corvette
1977 Z28
1979 Honda CBX 1000 6 cyl
Re: help my truck run cooler!! [Re: sdsnowman] #728934 06/06/06 08:01 AM
Snowtoy Offline
Virtually every 2nd gen runner I have come across has the A/C condensor fan, so you could probably get an oem one from a wrecking yard fairly cheap.
Re: help my truck run cooler!! [Re: sdsnowman] #728935 06/06/06 08:47 PM
Cholltero Offline
Didn't you and I have a phone conversation about a year ago and you were having simular probs (was it a head problem at the time) ??
I 'd test your fan clutch . You should hear it "roar" into action as soon as your engine is getting a little over heated . Same sound as in the first thing in the morning when your warmup idle is initially high and it takes maybe 30 secs to for the fan to loosen up . They usually last a little longer than 3 years but you never know.
Also , when I 'm toubleshooting a cooling system , I'll take the radiator cap off , take out coolant till there's only about 1/2 " of coolant over the tubes , start the motor and bring it up to temp with a themometer stuck in the fill neck so I can keep an eye on things. If your thermostat is working correctly , you should see intermitant coolant circulation as the temp reaches normal running conditions.
If you have a head problem , which can cause overheating and is very common, you may see "belching" of the coolant . You can also have the radiator tested for presence of CO
Be careful
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6151 MB (Peak: 0.7003 MB) Data Comp: Off Server Time: 2026-07-15 08:55:37 UTC
