U bolt size for 2wd #728974 06/05/06 01:43 AM
Vonka Offline OP
I have a lowered truck that I want it to be stock height.What's would be the size of the ubolt for the rear of a 1990 2wd PU truck?
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: U bolt size for 2wd [Re: Vonka] #728975 06/05/06 01:54 AM
4Crawler Offline
Don't know the size off-hand, but see if the u-bolts you have are made with extra threads (assuming the truck was lowered with blocks - X" of extra thread for an X" block). Then just re-use the bolts and cut them shorter as needed. Or measure what is on there now:
and subtract the block height from the measured "L" dimension.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5892 MB (Peak: 0.6373 MB) Data Comp: Off Server Time: 2026-06-07 04:23:43 UTC
