Noises!!
#728982
06/05/06 01:53 AM
Hi I have a 87' 4X4 Pickup and just recently drove it for the first time today. (Been working to make it drivable for the last month or two) Anyway when driving i noticed a very loud whine or grrrr noise, but this only happens when the clutch is let out. If you are simply sitting with the clutch pushed in then the noise is gone. I was thinking it was either the transfer case or a bearing in the transfer case, or a bearing in the transmission. It shifts just fine so its not the transmission itself. Any idea as to what it would be? Thanks for the replys a bunch!
Re: Noises!!
[Re: racerfan120]
#728983
06/05/06 02:48 AM
What about the clutch release bearing? I've had this on both w56 trannies I've had.
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
Re: Noises!!
[Re: Rauch_Off_Road]
#728984
06/05/06 03:18 AM
Wouldn't the throw out bearing make the noise while the pedal is pushed in too? try putting the transfer case in neutral and see if the noise goes away. Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
Re: Noises!!
[Re: Jeffstoyo]
#728985
06/05/06 03:26 AM
ya even in neutral on the 4wd it still makes the noise.
Re: Noises!!
[Re: racerfan120]
#728986
06/05/06 03:49 AM
input shaft bearing. i think
Re: Noises!!
[Re: 1986xtracab]
#728987
06/05/06 04:03 AM
The input shaft on the tranny or the transfer case?
Re: Noises!!
[Re: racerfan120]
#728988
06/05/06 04:32 AM
1986 xtra-cab 22re stock everything 1991 bed
Re: Noises!!
[Re: 1986xtracab]
#728989
06/05/06 05:59 AM
Yep, input shaft bearing (tranny).
Jerod
89 4Runner, 282k miles. "I gotta have more cow bell"
Re: Noises!!
[Re: 2ndGenToyotaFan]
#728990
06/06/06 04:41 AM
great thanks for the replys!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6257 MB (Peak: 0.7117 MB) Data Comp: Off Server Time: 2026-06-17 03:39:05 UTCValid HTML 5 and Valid CSS
