A/C compressor melting...now that's hot #729404 06/07/06 04:14 AM
ToyotaT Offline OP
Besides making a very loud bellowing the other day, my A/C compressor is spitting out burnt rubber or plastic when the A/C switch is on!
There is a crease between the pully and the front of the clutch mechanism where the junk is coming out of.
Tried it out again tonight and I thought it was locked solid because smoke and burnt rubber smell was coming from the hood as soon as I pushed in the button. When I took a closer look it was not the belt, but from the clutch of the compressor.
<img src="/forums/images/graemlins/confused.gif" alt="" /> Is it possible my clutch is just bad and not the whole compressor?
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: A/C compressor melting...now that's hot [Re: ToyotaT] #729405 06/07/06 07:02 AM
OOP'S Offline
No I would say the compressor is frozen and the clutch is slipping!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: A/C compressor melting...now that's hot [Re: ToyotaT] #729406 06/07/06 12:05 PM
Dandeman Offline
Toyota Moderator
Agree that you have a seized up compressor and you are just burning the clutch when you turn it on.. The clutch will very much have an odor like burning rubber or an electrical fire when you got it on with the compressor seized up... Been there...
<img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: A/C compressor melting...now that's hot [Re: ToyotaT] #729407 06/07/06 03:23 PM
RatLabGuy Offline
X3. Sorry.
Good news: I happen to have a compressor sititng in my garage if you're willing to give a used one a try.
Question Reality.
Re: A/C compressor melting...now that's hot [Re: RatLabGuy] #729408 06/07/06 04:02 PM
ToyotaT Offline OP
PM sent.
Anyone ever get a compressor from ackits.com? They only want 2 bills for the one they have. I purchased some parts from them a year ago and found them to be really helpful over the phone. A dryer/expansion valve (which is what I purchased) is different than a compressor though.
85 Toy Pickup
Re: A/C compressor melting...now that's hot [Re: ToyotaT] #729409 06/07/06 04:34 PM
Marc91runner Offline
I've been running my compressor from ackits for my 3rd summer now and it works fine. You might need a new dryer as well as flushing the system to remove any junk.
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed)
4.56, 31x10.5x15 Nokian Vatiiva's
Re: A/C compressor melting...now that's hot [Re: Marc91runner] #729410 06/07/06 06:36 PM
Dok Offline
ackits stuff is good, also check ebay, I picked up a rebuilt compressor for around $100 (PM me for the contact info if u want)
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: A/C compressor melting...now that's hot [Re: ToyotaT] #729411 06/07/06 09:47 PM
yodta Offline
sure it's not the pulley?
msg - '87 xtracab
Re: A/C compressor melting...now that's hot [Re: yodta] #729412 06/07/06 09:50 PM
ToyotaT Offline OP
Hmm. Not sure what you mean by the pulley. Everything works fine as long as the A/C button isn't pushed in though.
Anyone have any ideas if this could have happened from something I did wrong when I installed this? It worked fine last summer and several times this season... Just want to make sure I don't mess something up again if I did something wrong the first time. I would think something wrong would have shown its face earlier though....
85 Toy Pickup
Re: A/C compressor melting...now that's hot [Re: ToyotaT] #729413 06/08/06 01:37 AM
Smoke Offline
Be sure to use the proper amount of oil and also the right type.
94 P/U Ex-Cab 3.0 Automatic 4X4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6346 MB (Peak: 0.7389 MB) Data Comp: Off Server Time: 2026-06-10 07:23:09 UTC
