Where is my horn? #729571 06/07/06 10:29 PM
V
Voyager Offline OP
It's sort of embarrassing really. I've owned this truck for three years and never noticed I didn't have one. I guess I wasn't much of a horn user. Well a year of living in the Northeast has revealled my lack of horn! <img src="/forums/images/graemlins/lol.gif" alt="" />
Where is it supposed to be? I can't find it in my engine compartment though it looks like there's a clean spot on the drivers firewall. Is that where it should be mounted?
Just wanted to make sure before I bought one on ebay. Also, what does the wiring plug that connects to it look like? I'll try to locate that as well. Thanks.
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: Where is my horn? [Re: Voyager] #729572 06/07/06 10:45 PM
TexJeff87 Offline
It's behind the grill.
If Mad Max had a 4runner...
Re: Where is my horn? [Re: TexJeff87] #729573 06/07/06 11:40 PM
V
Voyager Offline OP
Thanks Tex! <img src="/forums/images/graemlins/cheers.gif" alt="" /> Yup, it's in there. Let the troubleshooting begin.
Sid
Re: Where is my horn? [Re: Voyager] #729574 06/07/06 11:51 PM
P
Paul_H Offline
Mines been dead for about 5 years, I've substituted the middle finger <img src="/forums/images/graemlins/notooth.gif" alt="" />
I should replace it one of these days, our roads are getting more crowded, and the drivers seem to be getting worse as well <img src="/forums/images/graemlins/nana.gif" alt="" />
'94 extra-cab 3.0 extra slo (auto tranny) original owner. E/B o/s valve heads and no more crossover. More mods to come.
Re: Where is my horn? [Re: Paul_H] #729575 06/07/06 11:55 PM
abnormaltoy Offline
Hey! I have the same one!!!
I would rather suffer the consequences of a Conservative?s error, than suffer the consequences of a Socialist's intent.
Re: Where is my horn? [Re: abnormaltoy] #729576 06/08/06 12:08 AM
TheBandit Offline
Mine has only worked once in the five years I've owned my truck. The time it worked was when I said to my brother "yeah, the horn doesn't work... see?" and of course that ONE time it worked! It was a freak incident.
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: Where is my horn? [Re: Voyager] #729577 06/08/06 12:30 AM
Jeffstoyo Offline
90% of the time, it is the horn contact mounted behind the steering wheel. Pull the steering wheel and you will see a brass ring. Pull it off and put a small washer under it at the three screws. This will help it have a better contact with the pin. You can get a replacement pin from the dealer and just pull the switch assy and it has a C-clip that you need to remove and undo the wire and replace.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Where is my horn? [Re: Jeffstoyo] #729578 06/08/06 12:48 AM
Staceman Offline
x2
fixed mine, and my neighbors!
Re: Where is my horn? [Re: Voyager] #729579 06/08/06 01:09 AM
kewlynx Offline
Check your fuse before you go tearing into the steering wheel.
**ubi apis- ibi salus**
Re: Where is my horn? [Re: kewlynx] #729580 06/08/06 01:22 AM
RatLabGuy Offline
x2 on the fuse. Its the same as the hazard flashers - do they work?
Question Reality.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6387 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-11-18 11:46:11 UTC
