Re: Where is my horn? [Re: RatLabGuy] #729581 06/08/06 01:53 AM
V
Voyager Offline OP
Thanks for the help. Yea, the hazards work. I pulled the wheel and saw the ring, but didn't pull it off. I cleaned all the contact points and lubed them with vaseline but nothing yet. The horn works in direct circut with the battery. I'll try little washers behind the ring next, that's a good idea. The pin seems to have a spring (like ballpoint pen size) behind it. Can that spring be replaced with a heavier one?
Thanks again.
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: Where is my horn? [Re: Voyager] #729582 06/08/06 04:43 PM
Jeffstoyo Offline
You could replace the spring, but I have had pretty good luck with the washers. You could order a new contact pin from the dealer also.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Where is my horn? [Re: Jeffstoyo] #729583 06/08/06 06:20 PM
V
Voyager Offline OP
Cool! Thanks Jeff. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Sid
Re: Where is my horn? [Re: Voyager] #729584 06/09/06 12:27 AM
Jeffstoyo Offline
No problem any time. I have owned and worked on Toyota's since 1988. I still have my first one too. I like to share and help out anytime I can.
Jeff
It's all good!
Re: Where is my horn? [Re: Voyager] #729585 06/09/06 12:01 PM
foxtrapper Offline
Before you bother trouble shooting the horn, replace it. The factory horn is about as powerfull as a kiddie bicycle bell. Pedestrians at ten feet can hear it, but that's about it.
'97 T-100 SR5
Re: Where is my horn? [Re: foxtrapper] #729586 06/09/06 08:04 PM
Jeffstoyo Offline
I have hooked up air horns in all of my trucks. I do agree the factory horn is very wimpy. I use a relay to turn the compressor on using the factory horn wire as the relay trigger. Nothing like waking up the sleeping motorists that try to take over your lane too. <img src="/forums/images/graemlins/sleeping.gif" alt="" />
Jeff S.
It's all good!
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6166 MB (Peak: 0.7019 MB) Data Comp: Off Server Time: 2026-11-16 08:32:30 UTC
