Re: Where is my horn?
[Re: RatLabGuy]
#729581
06/08/06 01:53 AM
Thanks for the help. Yea, the hazards work. I pulled the wheel and saw the ring, but didn't pull it off. I cleaned all the contact points and lubed them with vaseline but nothing yet. The horn works in direct circut with the battery. I'll try little washers behind the ring next, that's a good idea. The pin seems to have a spring (like ballpoint pen size) behind it. Can that spring be replaced with a heavier one?
Thanks again.
Sid
89 extra cab 4x4 3.0 5 spd, 216K 4.56, Supra LSD, Lock Rite
[Re: Voyager]
#729582
06/08/06 04:43 PM
You could replace the spring, but I have had pretty good luck with the washers. You could order a new contact pin from the dealer also. Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
[Re: Jeffstoyo]
#729583
06/08/06 06:20 PM
Cool! Thanks Jeff. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Sid
[Re: Voyager]
#729584
06/09/06 12:27 AM
No problem any time. I have owned and worked on Toyota's since 1988. I still have my first one too. I like to share and help out anytime I can. Jeff
[Re: Voyager]
#729585
06/09/06 12:01 PM
Before you bother trouble shooting the horn, replace it. The factory horn is about as powerfull as a kiddie bicycle bell. Pedestrians at ten feet can hear it, but that's about it.
'97 T-100 SR5 '86 Toyota's, the variety pack (all gone)
[Re: foxtrapper]
#729586
06/09/06 08:04 PM
I have hooked up air horns in all of my trucks. I do agree the factory horn is very wimpy. I use a relay to turn the compressor on using the factory horn wire as the relay trigger. Nothing like waking up the sleeping motorists that try to take over your lane too. <img src="/forums/images/graemlins/sleeping.gif" alt="" /> Jeff S.
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6128 MB (Peak: 0.6981 MB) Data Comp: Off Server Time: 2026-11-02 19:13:20 UTCValid HTML 5 and Valid CSS
