T100 Fan Clutch runs whenever A/C is on. Normal? #729612 06/08/06 12:34 AM
hartzpad Offline OP
'96 T100 4x4 Xtracab 5 speed 127k miles
Whenever the A/C is on my engine's fax clutch engages and the fan really makes a lot of noise and really limits the power of the engine because of all the drag. It stays engaged through all gears and all RPM ranges (even past 4k RPM's).
I assume that this is not normal and I either need to replace the fan clutch or replace the fan with 2 electric fans with thermostats? Any advice or information?
Re: T100 Fan Clutch runs whenever A/C is on. Normal? [Re: hartzpad] #729613 06/08/06 03:55 AM
J_Bird Offline
I had a similar problem. My fan sounded like an airplane trying to take off. I changed the clutch out, and it ran like it was supposed to.
While swaping them, I compared them both while cool. You couldn't tell hardly any difference. I guess the heat coil in the new one didn't lock up as quick.
It was worth every penny.
P.S. Get a quality, long handle end wrench for this job. Size 13mm if I remember right. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: T100 Fan Clutch runs whenever A/C is on. Normal? [Re: J_Bird] #729614 06/08/06 05:55 AM
Your fan Engages anytime your a/c is on...this is normal.
Re: T100 Fan Clutch runs whenever A/C is on. Normal? #729615 06/08/06 03:25 PM
garym Offline
I don't know about that. The fan clutch system is based on a silicone fluid with viscosity characteristics that engage and disengage fan. It is based on speed and temp. The A/C never talks to the fan. Over a certain RPM the fan should freewheel.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: T100 Fan Clutch runs whenever A/C is on. Normal? [Re: J_Bird] #729616 06/08/06 04:27 PM
mikem Offline
So how hard is the replacement?
How much other stuff needs to be removed to do it right?
Any other special or unique tools needed?
Thanks
1995 T100 SR5 XCab 2WD Auto
Re: T100 Fan Clutch runs whenever A/C is on. Normal? [Re: mikem] #729617 06/09/06 12:07 AM
Jake97T Offline
nothing special, long wrench just saves you from the busted knuckles, 10-15 minutes with the right tools should do it. too bad i dont have my spare...could have given it to someone in need, its in storage 900 miles away.
Re: T100 Fan Clutch runs whenever A/C is on. Normal? [Re: mikem] #729618 06/09/06 04:46 AM
J_Bird Offline
It's real simple, the nuts are in tight quarters though.
Rember that the new clutch is supposed to set at a certain position, for a specified ammount of time, before being put on the truck. Instruction are included. I think it is 12 hours. I'm not certain though.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6116 MB (Peak: 0.6895 MB) Data Comp: Off Server Time: 2026-06-09 23:31:17 UTC
