How much Herculiner? #729932 06/09/06 01:59 AM
Storm Trooper Offline OP
I looking at spraying my trooper inside and out with Herculiner. How many gallons do you think it will take?
I've got all my carpet removed (that was a gross job) and my paint sucks. I want to just shoot it all with Herculiner and be done with it.
'91 Trooper
3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: How much Herculiner? [Re: Storm Trooper] #729933 06/09/06 04:00 AM
matthew Offline
how much of the outside?
2 gal. should do inside and the bottom 1/2 of the outside w/ 2 coats
what do you plan to "spray" this with.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: How much Herculiner? [Re: Storm Trooper] #729934 06/09/06 04:04 AM
CPOM Offline
Took me 1/2 +/- gallon to double coat a pup bed along with 1/3 way up the sides. I would say get a gallon and a qt. You should do it all with the gallon then you can return the unopened qt.
CHRIS
98 Amigo, 92 Pup
Re: How much Herculiner? [Re: matthew] #729935 06/09/06 02:34 PM
I was thinking the whole thing. Not a good idea?
I honestly don't know. A friend of mine and I were talking about it, and he said that if I get the liner, he's has what we would need to spray it on. I don't think there is a tool or piece if equipment this guy doesnt have. Do you have any spray recommendations? Should we brush it instead?
'91 Trooper
Re: How much Herculiner? [Re: Storm Trooper] #729936 06/09/06 02:47 PM
RobG Offline
What Matt's getting at is Herculiner is sold as a roll-on product. Not sure what would happen if you tried to spray it... maybe it will work. Other similar products like the DupliColor stuff sold at Advance Auto and Walmart are marketed as spray on products...
http://www.duplicolor.com/products/truckbed.html
-Rob
EDIT, fyi, i just found this... though I haven't talked to anyone that's spray'd Herc before:
http://www.herculiner.com/images/spray_instructions.pdf
Re: How much Herculiner? [Re: RobG] #729937 06/09/06 03:26 PM
Yep, that's the same page my friend was showing me.
'91 Trooper
Re: How much Herculiner? [Re: Storm Trooper] #729938 06/09/06 04:44 PM
CPOM Offline
I just read the insructions and it looks like it might not be a bad idea to spray it. I like the step where it says "apply herc UV protectant" . Might want to pickup some of that because it faded pretty quickly after a few days in the sun.
It's a pretty rough final surface, I think spraying the whole truck might make the truck look like a tennis ball but whatever floats your boat.
CHRIS
98 Amigo, 92 Pup
Re: How much Herculiner? [Re: CPOM] #729939 06/09/06 05:40 PM
Jonesy Offline
To do the inside and outside in full I think 2 gallons would do it. If you wanted to scrimp then I would buy 1 gallon and 4 quarts...then you can either return or store whatever you have left of quarts. I know a buddy of mine and myself split a gallon...I did my rocker panels(2 coats) he did his boulder bars and part of his tailgate(2 coats) and we still had about a half a gallon left.
I just touched it up after 3 years, and did my rear bumper with about half a quart.
Steve
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: How much Herculiner? [Re: Jonesy] #729940 06/09/06 06:45 PM
thepcguy Offline
I just finished the inside floor of my trooper with the Duplicolor stuff smile. I rolled it on ::shifty eyes::. Not perfect, but it'll help for a few years. Then I'll coat it again.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: How much Herculiner? [Re: CPOM] #729941 06/09/06 07:12 PM
Pops1 Offline
May make the truck look like a tennis ball
The Black is Off the shelf Hurculiner with Green smooth Durabak over for the two tone. You can buy this stuff in a pallet of colors and three textures.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6444 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-11-03 13:18:27 UTC
