Engine replacement issues.... #729965 06/09/06 06:03 AM
A
ATCGuy Offline OP
I have a 95SR, and the engine was supposedly replaced with a rebuilt engine a few months ago. Without going into too many details just yet, let's just say I am growing more and more suspicious that this was not the case.
Is there a serial number on the block somewhere? Am I correct in assuming that in a true, "long block" rebuild, the crankshaft pulley and timing covers would be replaced. (Among other things of course.)
Re: Engine replacement issues.... [Re: ATCGuy] #729966 06/09/06 07:14 AM
DirtyOldTown Offline
When I was working at a dealer (though not a Mitsu dealer) and we rebuilt/replaced an engine, we reused the old timing cover(s), valve covers, brackets, pulleys, etc. unless it was necessary to replace them. What's up? Is it not running well? If the only problem is that they re-used the timing cover and the crank pulley then I wouldn't worry about it. If it's smoking or knocking or something like that, then I'd worry. Was it done at the dealer?
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
Re: Engine replacement issues.... [Re: ATCGuy] #729967 06/09/06 09:21 AM
O
ojo1 Offline
I wouldn't anticipate any pullies or covers to be replaced unless they were damaged - and then only if they would cause a problem.
All bearings, rings, seals and gaskits should have been done.
Re: Engine replacement issues.... [Re: ATCGuy] #729968 06/10/06 06:40 AM
TobyB Offline
Doesn't help you much now,
but the heads have 2- digit numbers cast into them, in rather large digits. They're all different (enough, like a date code or something)
that you can tell which head is which, and if you had gotten the same 2 numbers, odds are very good that the engine's the same.
(mine has 9 and 32- that's how I kept left and right identified. Not that it really matters at all...)
I seem to remember that there's a number on the back of the block, on a flat, machined pad close to the ehad sealing surface- but I don't think that the number matches the VIN or anything as easy as that...
fwiw,
t
'89 V6 4dr- '4- Doris'
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6017 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-07 05:43:21 UTC
