Receiver Winch Mount #729996 06/09/06 05:31 PM
TOY4ICK Offline OP
I'm considering adding a 2" receiver to the front of my 4Runner for using a removable winch mount. What are your thoughts on such a setup? I don't tend to do much winching when I'm wheeling and don't plan to hang my truck from it. Thanks.
'86 4Runner SR5 - 22R-EB with V-6 Throttlebody, 2" 4Crawler B.L., Ball Joint Spacers, Rock SliderZ, TJ Coils, 5.29's, Rear Locker, 33" Duratracs
Re: Receiver Winch Mount [Re: TOY4ICK] #729997 06/09/06 06:04 PM
DirtyHarry Offline
Toyota Moderator
I think that they are good if you don't do much winching, but you need a place to store the winch when you are not using it. You don't want 100 pounds of steel bouncing around in the back of your truck but they kill approach angle so you can't really leave it on the front all the time. In rockcrawling situations some times you can't add the winch to the front because your bumper is up against a rock or similar obstacle. All that said though, they are a far better option than not having a winch at all.
Re: Receiver Winch Mount [Re: TOY4ICK] #729998 06/09/06 07:38 PM
One time is all it takes. So if you are going to do it, do it right. I'm not saying this is how you feel but by the sound of your quote,you are thinking about just rigging something up to work "if" you need it. That can be a recipe for disaster.
Re: Receiver Winch Mount #729999 06/09/06 09:25 PM
TOY4ICK Offline OP
I plan on something stout and well engineered but also removable. My point was just that I don't usually do much winching. I certainly want it to be safe and reliable when I am using it.
Re: Receiver Winch Mount [Re: TOY4ICK] #730000 06/09/06 09:39 PM
P
Paul_H Offline
I've thought about the same setup, with the added benefit you can run the winch off the rear receiver hitch. Also you keep the winch out of the elements during all the times you aren't using it.
'94 extra-cab 3.0 extra slo (auto tranny) original owner. E/B o/s valve heads and no more crossover. More mods to come.
Re: Receiver Winch Mount [Re: Paul_H] #730001 06/09/06 11:09 PM
Rauch_Off_Road Offline
Here is what I have so far. I plan to weld on the reciever that is currently bolted on eventually. I think it is a sturdy design and this way I don't have to drag that winch around with me all day as this is my DD.
http://www.4x4wire.com/forums/showf...;oldertype=&bodyprev=#Post813236
(aka suprathepeg, aka Sean)
Re: Receiver Winch Mount [Re: TOY4ICK] #730002 06/09/06 11:22 PM
Smoke Offline
It can be useful and can be also used as a winch for loading a disabled vehicle on a trailer by welding a reciever on the front of trailer.
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: Receiver Winch Mount [Re: TOY4ICK] #730003 06/10/06 12:53 AM
ldivinag Offline
here's my setup that i've had for years:
and in action:
it sticks out just a "wee"... <img src="/forums/images/graemlins/wink.gif" alt="" />
but if needed, it can popped out in seconds...
i also have a 22' feet of 1/0 guage "extension" power/ground cable that runs to the back (or ANOTHER VEHICLE!!!!!) and winch that way.
i have tested it by doing a triangular winch where the cable exited to the extreme right. i then used a snatch block to a tree to the right side and then attached the hook to my hitch point to the rear bumper.
i was sliding off a muddy uphill trail and by winching that way, i was able to pull myself a foot or away from the left side where it just drops down...
the friend who came up with the front mount isnt a wheeler, but an excellent welder and i told him i want a bulletproof mount up front...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Receiver Winch Mount [Re: ldivinag] #730004 06/11/06 01:34 AM
TOY4ICK Offline OP
Thanks for the pictures, I'll post some when mine is done.
Re: Receiver Winch Mount [Re: TOY4ICK] #730005 06/11/06 03:35 AM
A
allochris Offline
Built this a long time ago, but never have a winch yet to try it out... There are total of 4 bolts to capture nuts plus 3 others bolts/nuts across the crossmember-square tubing not mounted in the pictures.
[image]
www.eng.uwaterloo.ca/~mhcho/CIMG6521.JPG
[/image]
[image]
www.eng.uwaterloo.ca/~mhcho/CIMG6520.JPG
[/image]
[image]
www.eng.uwaterloo.ca/~mhcho/CIMG6518.JPG
[/image]
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6403 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-05-29 22:19:51 UTC
