Replacing radiator #730037 06/09/06 08:37 PM
smd94trooper Offline OP
I just got my new radiator from radiator barn (next day delivery because they had a warehouse in Texas) and I am planning on installing it tonight. Is there anything else that I need to do when I replace it like flush the system or replace anything. I know I need to replace the radiator cap and when I refill the thing I need to do 50/50 with coolant/distilled(?) water but I was thinking that maybe there was something I'm missing like a pre-flush or something.
By the way, my hoses are good(recently replaced both upper and lower) and everything else seems to be working properly.
Stefan Doerr
'94 Trooper LS
6.5" lift, 33's, G80 and other stuff
http://community.webshots.com/user/smd94trooper
Re: Replacing radiator [Re: smd94trooper] #730038 06/09/06 11:33 PM
sweater Offline
I think you'll find that when you drain it and then pull it, you're going to accomplish that very thing by swapping out pretty much all of the coolant.
It's a messy, keep-your-dog-away-from-the-puddles-of-coolant sort of job but not too difficult.
- mike
Re: Replacing radiator [Re: sweater] #730039 06/09/06 11:36 PM
CPOM Offline
Yeah like Mike hinted be careful to seal all containers of the used coolant and wash the ground well of any spilled as its very toxic to animals.
CHRIS
98 Amigo, 92 Pup
Re: Replacing radiator [Re: CPOM] #730040 06/10/06 12:08 AM
check <img src="/forums/images/graemlins/kewl.gif" alt="" />
so there's no obvious preventative maintenance while I'm messing with the cooling system?
Stefan Doerr
'94 Trooper LS
Re: Replacing radiator [Re: smd94trooper] #730041 06/10/06 01:39 AM
JLEMOND Offline
ONE MORE STEP IF IT IS AN AUTOMATIC TRANS CHANGE THE TRANNY COOLER LINE WHILE EVERYTHING IS OUT OF THE WAY , AND USE USE GOOD HI PRESSURE OIL PROOF HOSE JERRY
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6063 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-11-02 08:28:31 UTC
