overheating sitting still? #730554 06/12/06 04:53 AM
turtleskia Offline OP
i was sitting at a drive thru window recently, and noticed the temp. gauge was slowly climbing up. is this common with the sportage? has anyone else had this problem? my wife drives a sephia and we've never had an overheating problem with it.
Re: overheating sitting still? [Re: turtleskia] #730555 06/12/06 01:06 PM
Dave Scott Offline
2 things: either you need coolant or your fan clutch is out. happens, to ALL cars.
Re: overheating sitting still? [Re: Dave Scott] #730556 06/12/06 01:30 PM
maraguez Offline
Replace your fan with an electric one, you will appreciate it in the long run.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
Re: overheating sitting still? [Re: maraguez] #730557 06/12/06 03:53 PM
Dave Scott Offline
ha, edit- one more thing: thermostat.
Re: overheating sitting still? [Re: Dave Scott] #730558 06/14/06 04:32 AM
DamKia Offline
Kia Moderator
Suss waterpump???? (OK at speed, not good at idle)
Blocked external fins to the radiator (Been through mud/dust/insects???)
Re: overheating sitting still? [Re: turtleskia] #730559 06/15/06 11:55 PM
KyleLovesHisKia Offline
My 2000 was doing the same thing, temperature rising when standing still...had a bad fan clutch...easy to change...$120 for fan assembly from Kia.
Re: overheating sitting still? [Re: KyleLovesHisKia] #730560 06/16/06 03:56 AM
Nukeiridium Offline
My Sportage used to be picky about cooling, it liked to overheat sometimes...
I switched to an electric fan and never looked back! We get 120 degree weather sometimes and my Sportage won't overheat no matter what I do!
It also helps to have a good radiator. This might sound strange but last time I replaced my radiator, I put in a copper radiator instead of the aluminum, because it was cheaper. Well folks, I swear the copper has done a better cooling job... and it was cheaper...
It makes sense I guess since copper is a better conductor than aluminum, you just gotta be careful it's not as rugged as aluminum (or something like that) and it's heavier for sure.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: overheating sitting still? [Re: Nukeiridium] #730561 06/16/06 04:25 AM
flyboy367 Offline
i flip my e-fan on for 10 seconds and its ice cool again. do the efan swap you save hp and gas in the long run
1995 nissan maxima se, 5spd short throw, aluminum flywheel and crank pully, stage 3 clutch, custom ported top end, full 2.5 exhaust jdm front end
Re: overheating sitting still? [Re: flyboy367] #730562 06/17/06 04:01 AM
tlab Offline
I have a brand spankin new Fan Clutch that was never used. I bought it for the sportage and then traded it and I still have some parts left over. If your interested in it just PM me or email me [email]triston@enter.net.[/email] I'll take $50 for it + the cost of shipping. that shouldn't be too damn exspensive. I think I payed $120 for it.
2001 dodge dakota bone stock right now.
check out the last love of my life on .....
http://members.cardomain.com/tlab1
Re: overheating sitting still? [Re: Dave Scott] #730563 07/17/06 05:05 AM
thanks for the info guys, but now i feel really stupid. i finally got a chance to check the radiator, and even bought the thermostat to replace, but decided to check the coolant levels first. wouldn't ya know, it was half a gallon low. so i refilled the radiator with 50/50 from the parts store and it runs like a top. now to get the oil changed.
95 sportage, gone and severly missed.
94 camaro 5-speed v6 with a few addons.
girlfriends 93 s-10 4.3 soon to be lifted and made into a pre-runner
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6367 MB (Peak: 0.7599 MB) Data Comp: Off Server Time: 2026-05-29 14:33:04 UTC
