Oil Leak From Bell Housing
#730601
06/12/06 12:17 PM
For some time now i've had an oil leak which looks like its coming from the bell housing. I'm just wondering if replacing the seals will be an easy job or not? does anyone have any diagrams or info which may help me..
Cheers
=== Gem ==== 91 4 Runner SR5 V6 3L Manual
Re: Oil Leak From Bell Housing
[Re: West_Aussie]
#730602
06/12/06 12:56 PM
Toyota Moderator
If it's the rear main it's not too bad, if you know how to pull the trans and replace the clutch that's most of the work right there. FYI however before you start on that make sure that's where it's coming from. My head gaskets are seeping at the rear and it drips down to under the bell housing, looks like it's coming from inside but it's not.
Bill 97 SR5 4WD Yukon 4.88s, ARB locker front/rear, OME Lift w/ Cornfeds, 2 Body lift, Panhard drop, Custom gauges, Nuke discos, TJM T17, My Runner
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5864 MB (Peak: 0.6341 MB) Data Comp: Off Server Time: 2026-05-29 15:22:15 UTCValid HTML 5 and Valid CSS
