Parking Light Bulb Replacement #730648 06/12/06 04:59 PM
wademan Offline OP
Can anyone point me towards any info on replacing this bulb (front, driver on a 2002)? Just noticed it was out last night and (at least with a flashlight) it seems like it's pretty tough to get to.
Thanks!
02 Taco 4x4, V6, TRD
Re: Parking Light Bulb Replacement [Re: wademan] #730649 06/13/06 03:32 PM
Mark in AZ Offline
Toyota Moderator
The one in the fender?
Mine was held in place with a Phillips head screw that you will see when you lift the hood. Remove the screw and begin rocking the housing up and down while pulling it towards the front of the vehicle. It may be fairly snug, but it is just a press fit. Once it's out, remove the factory socket from the housing by twisting it counter-clockwise.
Exploring in a T4R Ltd V8
Re: Parking Light Bulb Replacement [Re: Mark in AZ] #730650 06/13/06 03:37 PM
mark got it dead on
Re: Parking Light Bulb Replacement #730651 06/14/06 08:15 PM
wademan Offline OP
I was led to believe that is was a larger hassle than you describe. I always get good help here! Thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Parking Light Bulb Replacement [Re: wademan] #730652 12/27/06 09:45 PM
pherrell Offline
Would this be the same for a 99 Tacoma b/c it seems there is a bolt behind it holding the parking light to the truck?
Re: Parking Light Bulb Replacement [Re: pherrell] #730653 12/28/06 02:16 AM
RichinROA Offline
If I recall, its the same for 1999s.
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: Parking Light Bulb Replacement [Re: pherrell] #730654 12/28/06 09:26 AM
humanoid Offline
I believe Mark's procedure works for all model Tacos '95.5-'04.
Re: Parking Light Bulb Replacement [Re: pherrell] #730655 12/28/06 03:41 PM
Mark in AZ Offline
Toyota Moderator
Looky there, the search function does work <img src="/forums/images/graemlins/wink.gif" alt="" />
pherrell, I'm in Chandler...stop by and we can check it out.
Re: Parking Light Bulb Replacement [Re: Mark in AZ] #730656 12/28/06 03:55 PM
pherrell Offline
Thanks Mark. I'll take another look today and see if I can get it out.
I like the saying you have RichinROA about coal mining. Born and raised in WV and I was actually just back there for Thanksgiving.
Re: Parking Light Bulb Replacement [Re: pherrell] #730657 01/02/07 10:50 PM
RichinROA Offline
As sad as it is, it's 100% true. If you aren't a welder, chemist, engineer, or miner, there isn't much for ya in them hills.
99 TacoTRD 177K
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6369 MB (Peak: 0.7421 MB) Data Comp: Off Server Time: 2026-05-29 14:53:52 UTC
