Parking Light Bulb Replacement
#730648
06/12/06 04:59 PM
Can anyone point me towards any info on replacing this bulb (front, driver on a 2002)? Just noticed it was out last night and (at least with a flashlight) it seems like it's pretty tough to get to.
Thanks!
--- 02 Taco 4x4, V6, TRD
Re: Parking Light Bulb Replacement
[Re: wademan]
#730649
06/13/06 03:32 PM
Toyota Moderator
The one in the fender?
Mine was held in place with a Phillips head screw that you will see when you lift the hood. Remove the screw and begin rocking the housing up and down while pulling it towards the front of the vehicle. It may be fairly snug, but it is just a press fit. Once it's out, remove the factory socket from the housing by twisting it counter-clockwise.
Wheeling a Stepside Tacoma on 37s Exploring in a T4R Ltd V8
#730651
06/14/06 08:15 PM
I was led to believe that is was a larger hassle than you describe. I always get good help here! Thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: wademan]
#730652
12/27/06 09:45 PM
Would this be the same for a 99 Tacoma b/c it seems there is a bolt behind it holding the parking light to the truck?
[Re: pherrell]
#730653
12/28/06 02:16 AM
If I recall, its the same for 1999s.
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
[Re: pherrell]
#730654
12/28/06 09:26 AM
I believe Mark's procedure works for all model Tacos '95.5-'04.
[Re: pherrell]
#730655
12/28/06 03:41 PM
Toyota Moderator
Looky there, the search function does work <img src="/forums/images/graemlins/wink.gif" alt="" />
pherrell, I'm in Chandler...stop by and we can check it out.
[Re: Mark in AZ]
#730656
12/28/06 03:55 PM
Thanks Mark. I'll take another look today and see if I can get it out.
I like the saying you have RichinROA about coal mining. Born and raised in WV and I was actually just back there for Thanksgiving.
[Re: pherrell]
#730657
01/02/07 10:50 PM
I like the saying you have RichinROA about coal mining. Born and raised in WV and I was actually just back there for Thanksgiving. As sad as it is, it's 100% true. If you aren't a welder, chemist, engineer, or miner, there isn't much for ya in them hills.
99 TacoTRD 177K
