Broke my 94 PU #730690 06/12/06 09:42 PM
bigdirtdog Offline OP
Just last weekend I suddenly left the road doing 50+. As I cleared the 3' culvert drop hit the slope which thru me about 30' before ending up in a hay field. Front axle, Control Arm-upper&lower and steering relay rod, ball joints, etc. etc. My question is finding the best deals and parts. For example I can get Front axles from Marlin Crawler which seem to be pretty beefy and might be a good upgrade, but they are expensive. Any help ideas from all gear heads would be appreciated. Thanks Bigdog
94 xtra-cab 4x4 V6 98k, K&N intake, Custom Flowmaster exhaust, Edelbrock IAS Shocks, Cross-Drilled Vented Disc, 31x10.50 AT on American Racing wheels, Hella Headlights 90/130W and Corbeau Sports seats, Addco Sway Bars FR & RR.
Re: Broke my 94 PU [Re: bigdirtdog] #730691 06/12/06 09:52 PM
A
allochris Offline
Are u ok? Got thrown in the air for 30'!!!
Anyway, do u mean that u're looking forward for a SAS? Instead of fixing your broken ifs parts?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Broke my 94 PU [Re: allochris] #730692 06/12/06 10:17 PM
J94_4runner Offline
Dukes of Hazzard style right there.... General Lee'n it.
Use Moog Chasis parts (Ball joints and TRE's). Try to find a Tropical Int. parts supplier in your area. they have pretty good prices on Moog parts.
www.celicasupra.com
Re: Broke my 94 PU [Re: bigdirtdog] #730693 06/13/06 01:25 AM
Snowtoy Offline
Glad to hear you came through relatively unscathed.
Re: Broke my 94 PU [Re: bigdirtdog] #730694 06/13/06 04:52 AM
trythis Offline
Pictures pictures pictures!!!!
Re: Broke my 94 PU [Re: trythis] #730695 06/13/06 06:01 AM
Aaron84x4 Offline
second pictures. glad your ok, bet it was one hell of a ride while it lasted tho... <img src="/forums/images/graemlins/scared.gif" alt="" />
84x4 Toyota Ext. Cab Deluxe
Not enough hours in the day to do what i want.....
.....and sleep
Re: Broke my 94 PU [Re: bigdirtdog] #730696 06/13/06 05:56 PM
Thanks too all you guys, I came out of it fine just crush by my own problems of being Diabetic. Drove my truck basicly passout from Low-Bloodsugar for about 25miles over cruvey counrty roads. I was very forunate not to hurt anyone else, and the problem of kind has never happen before in the 43 years that I have been a Diabetic,(and having this truck for 11years) this will take some serious self-refelection about my condition. But saving money on the rebuild would help. The upper control-arm thru Toyota is 318.78 Steering Knuckle is 286.40 and Front axle shaft is 116.00 and this is a IFS truck, does anyone have ideas on a source for better prices. Thanks Bigdog I'll try to post some pic's
Re: Broke my 94 PU [Re: bigdirtdog] #730697 06/13/06 08:10 PM
TOY4ICK Offline
I'm glad you're okay! If you're lucky, there is someone in your area who has performed an SAS on their truck and now has the parts you need laying in their yard or garage. Good Luck.
'86 4Runner SR5 - 22R-EB with V-6 Throttlebody, 2" 4Crawler B.L., Ball Joint Spacers, Rock SliderZ, TJ Coils, 5.29's, Rear Locker, 33" Duratracs
Re: Broke my 94 PU [Re: bigdirtdog] #730698 06/13/06 10:16 PM
Snowtoy Offline
Check Pirate4x4 or Marlin crawler forums sections for people in your area that has done an SAS. Some cut everything off and others take the time to unbolt it, even the ones that cut the top A-arms off the rest should be in good shape. Also check the local wrecking yards, you could probably find everything that that you need there, at far less than dealer prices. I would think that you should be able to get all of the pieces you used for less than the dealer price for just the A-arm. Used cv axles sell for about $20-30, the upper A-arms should be free-from a private party to about $100 from a wrecking yard, etc. I would buy new ball joints, tie rod ends, pitman and idler arms over installing used, unless they are comming off an SAS'd rig and don't have that many miles on them.
Re: Broke my 94 PU [Re: Snowtoy] #730699 06/13/06 10:23 PM
ToYPU Offline
i would get the "might-as-well" syndrome...
since my IFS is broke I "might-as-well" make it a solid axle hahaha
if not... EBAY, if not... Junkyard!
good think your ok!
good luck!
kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6330 MB (Peak: 0.7407 MB) Data Comp: Off Server Time: 2026-05-26 03:44:52 UTC
