Door Removal #730744 06/13/06 12:53 AM
kfunk Offline OP
On a YJ, after i remove the hard doors, how do i dismantle the interior lights and buzzer from staying on? is the preferred method to pull a fuse, or disconnect the button on the door frame or what? thanks
Re: Door Removal [Re: kfunk] #730745 06/13/06 03:04 AM
BigJim Offline
Which ever floats your boat!
Re: Door Removal [Re: kfunk] #730746 06/13/06 04:00 AM
JeePete Offline
I always just pulled the wire off the switch. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Door Removal [Re: kfunk] #730747 06/13/06 04:02 AM
W
wyleone Offline
The fuse in question is used for other circuits as well. (I don't remember which) They can be bought from places like Quadratec Or you can make one out of a coke can. Mine is no longer hooked to the pin switchs because I forgot how to put the doors back on.... <img src="/forums/images/graemlins/notooth.gif" alt="" /> It is hooked to a toggle switch so I can flip it on when needed.
Re: Door Removal [Re: kfunk] #730748 06/13/06 06:47 AM
I just removed the alarm because I hate those damn things and I hooked the inside lights to a toggle switch.
Re: Door Removal [Re: BigJim] #730749 06/14/06 06:03 PM
kfunk Offline OP
thanks, it seems to me that pulling a fuse would be the simpler option. do you know which fuse # to pull, is it the fuse box under the dash or the one under the hood? It will only dismantle the interior lights/buzzer and nothing else right? thanks for the help
Re: Door Removal [Re: kfunk] #730750 06/14/06 10:00 PM
F
Fred Blackstone Offline
disconnect the wire behind the door switch, just like Jeepete said. Keep it simple!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6884 MB) Data Comp: Off Server Time: 2026-05-30 00:12:36 UTC
