22re crank wont turn? #730777 06/13/06 04:45 AM
ToYPU Offline OP
put new crank bearings in the 22re while it was still in the truck, what would cause the crank to lock up tight? so tight i cannot turn even if i hang on a 1/2in drive ratchet... whats the deal?
no its not in gear...
thanks kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: 22re crank wont turn? [Re: ToYPU] #730778 06/13/06 04:50 AM
kyle-22r Offline
you didn't put oversized bearings on a standard journal crank, did you?
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 22re crank wont turn? [Re: kyle-22r] #730779 06/13/06 04:56 AM
P
poolville02 Offline
thats what it sounds like. if not, take out the plugs...but dont force it. rod bearings btw...
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
Re: 22re crank wont turn? [Re: poolville02] #730780 06/13/06 10:13 PM
ToYPU Offline OP
nope... crank is .010 and so are the bearings...
* New mods *
  • minor body work
Re: 22re crank wont turn? [Re: ToYPU] #730781 06/13/06 10:49 PM
P
poolville02 Offline
just to clear up, are we talking about rod bearings OR main bearings? I assumed rod bearings since you said you did this while still in the truck.
Re: 22re crank wont turn? [Re: poolville02] #730782 06/13/06 10:51 PM
yodta Offline
can you post a little more info surrounding the reason for this rebuild?
did it turn before, or was it locked up?
you can't rotate it either way?
msg - '87 xtracab
Re: 22re crank wont turn? [Re: yodta] #730783 06/15/06 01:38 AM
ToYPU Offline OP
put a main cap on backwards opps... bearings and crank looked fine... hope it runs
NOW I STRIPPED A HEAD BOLT, WAS ONLY ON THE SECOND PASS ON THE TORQUE SEQUENCE ABOUT 40 FT LBS?
HELI COIL?
THANKS KEVIN
* New mods *
  • minor body work
Re: 22re crank wont turn? [Re: ToYPU] #730784 06/15/06 01:48 AM
Just did the same thing, very hard size to find 12mm x 1.25
I had to order mine from toolsqwik off ebay they got the kit.I decided not to get my head milled like an @ss and stripped my exhaust side out.
Re: 22re crank wont turn? [Re: ToYPU] #730785 06/15/06 02:06 AM
P
poolville02 Offline
I was just about to say that; I did the same thing during my assembly and couldnt figure out what I did wrong.
Re: 22re crank wont turn? [Re: poolville02] #730786 06/16/06 12:28 AM
ToYPU Offline OP
oh man what a F%^K!#& pain in the ballz!!
im about to run the motor with 1 less head bolt!
* New mods *
  • minor body work
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6375 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-06-20 18:13:26 UTC
