Any idea what size bolts are used for stock TJ Skid Plate? #730936 06/13/06 11:22 PM
Macdaddy4738 Offline OP
My TJ skid plate (the one that covers the tranny/transfer case area) appears to have been attached with self tapping sheet metal screws on one side <img src="/forums/images/graemlins/scared.gif" alt="" />
My best guess is the Tranny shop lost the stock bolts when they installed a new clutch a while ago. In any case, any one know the stock bolt sizes so i can reinstall them?
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: Macdaddy4738] #730937 06/14/06 03:26 PM
zxkevinxz Offline
You won't be able to reinstall if they used self tappers 'cause doing that changed the threads. Might use a drill, bolts, nuts, washers, and locktight.
"Not all who wander are lost"
86 CJ7; 258,MC2100,30/300/44,2.5" susp. lift,31s
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: zxkevinxz] #730938 06/14/06 05:01 PM
they drilled new holes into the frame, the stock bolt holes are still there.
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: Macdaddy4738] #730939 06/14/06 09:11 PM
Chris72 Offline
Is the frame hole threaded, or is there a nut welded inside the frame before it was boxed? I had one of those on the skid plate on my CJ that came loose. Someone before me actually drilled a hole in the side of the frame rail so they could get a wrench on the nut to take the cross member off, rewelded the nut, then patched the access hole.
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: Macdaddy4738] #730940 06/15/06 01:53 AM
JeePete Offline
Can't you pull one out of the other side and see what size it is? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: JeePete] #730941 06/15/06 02:23 AM
I would take em off, but Im afraid of not being able to get the plate back on, the thing is rediculously heavy.
I dont THINK its like that, im pretty sure its threaded..
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: Macdaddy4738] #730942 06/15/06 03:26 AM
Put a jack under it....
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: Macdaddy4738] #730943 06/15/06 05:45 PM
Disconnect the tranny at the mount and support the tranny w/ a jackstand
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: Macdaddy4738] #730944 06/15/06 08:31 PM
F
fidgit Offline
That shope would have alot of problems with me and I mean alot drilling into my frame would be grounds for..... you get the idea,
Re: Any idea what size bolts are used for stock TJ Skid Plate? [Re: fidgit] #730945 06/16/06 05:21 AM
I dont know for sure if thats what happened, They where there when I found it...
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6327 MB (Peak: 0.7346 MB) Data Comp: Off Server Time: 2026-07-13 03:41:34 UTC
