Page 2 of 8 1 2 3 4 5 6 7 8
Re: A Beautiful Sight [Re: paulevans76] #731159 07/18/06 12:45 AM
Bigpoppax2 Offline
Looks good with the 35's. I assume the rear hasn't had any work done yet?
Nice job so far.
Joe
Re: A Beautiful Sight [Re: Bigpoppax2] #731160 07/18/06 01:03 AM
paulevans76 Offline OP
nope not yet. this week it gets sprung over.
for future reference if anyone needs some cheap spring perches, go to your local dodge dealership with this part number: P4120074. $10.50 +tax for the pair, though it may be a few dollars less or more depending <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Troop - Posing yard art
Re: A Beautiful Sight [Re: Bigpoppax2] #731161 07/18/06 01:03 AM
strawmyers Offline
Isuzu Moderator
That's the same welder I have (one of them anyway). Cool idea for the shackle placement. Seems like it will help keep the height down with less of a 'rock magnet' effect than many of the other shackles-up-front I have seen. How far foward are you extending the wheelbase? Can't wait to see some action pics <img src="/forums/images/graemlins/smile.gif" alt="" />
Sean Strawmyer
Re: A Beautiful Sight [Re: strawmyers] #731162 07/18/06 03:52 AM
E
Eric Upchurch Offline
This is that welders 3rd SAS, so good so far. I think the wheel base will end up around 110 or so. the set up is coming along nice so far, i like how the shackles are up higher and the axle is forward so it should have a nice aproach angle. hopefully we can get it finished before we get kicked out <img src="/forums/images/graemlins/shiner.gif" alt="" />
Eric
New rig: 89 trooper RS toyota axles with 5.29s, 35x15.5x15 swamper SXs
my Pics: http://community.webshots.com/album/124372714fTyMKI
Wrire up:http://personal.ecu.edu/emu0416/
Re: A Beautiful Sight [Re: Eric Upchurch] #731163 07/18/06 12:05 PM
axle is forward a good ways, probably 6 or 7 inches. I'm going to try to find some uncut fenders to start over with, since it looks a little goofy right now.
Re: A Beautiful Sight [Re: paulevans76] #731164 07/18/06 08:18 PM
randii Offline
I'm worried about those shackles swinging the spring eye right into the crossmember on full travel. Have you cycled the suspension to check?
Randii
Re: A Beautiful Sight [Re: randii] #731165 07/18/06 11:36 PM
The idea behind the hanger is that the crossmember will stop the shackle from inverting on extension (or when it is extended and I run it into something). And because the shackle mounts stick out a couple inches from the hanger, it has room to swing a little past verticle before it hits.
I dont remember running into interference when we were putting it together, but if the spring does hit then I'll have to run a longer shackle and move stuff again, or try different springs. wouldnt suprise me if that happened <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: A Beautiful Sight [Re: paulevans76] #731166 07/26/06 11:44 PM
oh I love sawzalling through solid steel brackets that HAVE to hang off the frame right where my steering is trying to be <img src="/forums/images/graemlins/shiner.gif" alt="" />
got my ford tre, inserts, jam nuts, and some tube for the drag link. sunday we will get that all together.
I also need to do the rear suspension. and theorhetically, I could just run add-a-leaves and a longer shackle for the time being. once I sat the truck down on its old 35's, it is suprisingly low. as in less than 4" taller in the front than the rear. but I doubt I could get the rear flex to balance with the front if it's stock leaves sua.
I could run some longer chevy springs in the rear, and the height and flex would be comparable, and they would probably wrap up less than the stockers- but that would be more work, time, and money than a simple soa. and since I'm planning on running some sort of linked rear before too long, why bother right <img src="/forums/images/graemlins/notooth.gif" alt="" />
I should get some pics sunday night of her complete enough to drive around a little and do the obligatory poser flex shots <img src="/forums/images/graemlins/mrt.gif" alt="" /> so stay tuned.
Re: A Beautiful Sight [Re: paulevans76] #731167 07/27/06 02:16 AM
matthew Offline
wassup with that tie rod .......... the ol' over under style? <img src="/forums/images/graemlins/lol.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: A Beautiful Sight [Re: matthew] #731168 07/27/06 12:17 PM
damnit someone noticed <img src="/forums/images/graemlins/shiner.gif" alt="" />
I haven't got a clue. it's been like that since I bought it and it is starting to drive me crazy. I guess that knuckle was swapped on from a different axle <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6435 MB (Peak: 0.7694 MB) Data Comp: Off Server Time: 2026-05-29 15:27:33 UTC
