sound system for tall guy #731368 06/15/06 03:15 AM
im 6'4" tall and i have an 85 4x4 yota pickup regular cab and i want to put a system in my truck but i only have 7 inches between the back of my seat and the back of the cab please help the tall guy
Re: sound system for tall guy #731369 06/15/06 04:01 AM
justinmnhall Offline
same thing happened to me( 6'4" as well) First get a extended cab if you can. much more room for us. That is what I did after about a year. But to hold you over... I bought 8" subs, I still have to sell <img src="/forums/images/graemlins/smile.gif" alt="" /> but I had to make the boxes so they would fit. I did it wrong,(Fiberglass half a box) so my sug to you is fiberglass the back. I have alot of info saved on it so if you're intersted. the best that I used was a 600 watt 6x9 that ran off a sony 760w amp that I strapped with abungie cord right in front of the pass seat (bench). Pass. would complain a little but do they want a ride? <img src="/forums/images/graemlins/lol.gif" alt="" /> hope that helps.
87 ex-cab 4x4 D D
89 4runner Work in progress!
Re: sound system for tall guy [Re: justinmnhall] #731370 06/15/06 04:11 AM
Snowtoy Offline
The best system for a standard cab, is to use subs in the doors and mid ranges and highs in the dash, all ran through an amp and x-over. Now you aren't going to get the teeth jarring base out of the door subs, but you will get decent all around sound, without having a sub pointed at your back, and driving with your nknees by your ears <img src="/forums/images/graemlins/lol.gif" alt="" />. Besides, any type of sub in a box in the 7" of space behind the seat wont sound much better given the limited amount of room the box will have. If you have to have the big base sound effects, install a shell, or 1/4 shell and put the big 12-18" subs back there.
Re: sound system for tall guy [Re: Snowtoy] #731371 06/15/06 05:02 AM
salvo Offline
i have 5" speakers in the doors, 6x9 mounted in the factory location behind the seats... had to open up the holes to make em fit these are run off my deck... then i have a 10" sub in a box (box bought from walmart fit perfectly behind the seat) powered by a 400 watt amp... the system sounds good and has enough base to make everyone look from blocks away... Iv done enough systems to know that you don't need big to get good sound... oh and im 6, 2 so my seat is all the way back
Re: sound system for tall guy [Re: salvo] #731372 06/15/06 05:08 AM
trythis Offline
Those people that are looking at you are considering whether to shoot out your tires or to go fo the engine.
Re: sound system for tall guy [Re: trythis] #731373 06/15/06 02:15 PM
TexJeff87 Offline
If Mad Max had a 4runner...
Re: sound system for tall guy [Re: trythis] #731374 06/15/06 04:53 PM
G
Greg_Canada Offline
gas tank, more visible on 4runners tho///
89 4Runner
Re: sound system for tall guy [Re: Greg_Canada] #731375 06/15/06 08:34 PM
A
Andy87 Offline
When I had a reg. cab, I got some stock buckets to replace the bench seat, then put a 10" sub behind the passenger seat. I was able to fit a decent sized box behind the pass. seat, plus the seats were a lot more comfortable anyway.
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
Re: sound system for tall guy [Re: Andy87] #731376 06/15/06 10:38 PM
bassplaya Offline
although they dont sound as good as normal subs, i would try out a 10 or 12in bazooka tube. it would fit nice behind the seats, plus they are self powered. i got a 12 in mine and it works for me
94 Pickup DLX V6 stock as stock can be, but not for long.
Re: sound system for tall guy [Re: salvo] #731377 06/16/06 03:43 AM
you can realy slide the seat all the way back with a store bought box? if you can, please give me the part number from wal mart <img src="/forums/images/graemlins/notooth.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6354 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-06-10 06:32:46 UTC
