GM alternator wiring? #731401 06/15/06 04:06 AM
E
eastcoast Offline OP
hey folks, in the process of installing a GM alt into my 94 22re. ive got it pretty much done, however one wiring issue has me a little stumped. in one swap, posted here: http://www.rocketcityrockcrawlers.c...ner%20alternator%20Upgrade%20Project.pdf
the two wires are listed as being #1 as the field wire and #2 as the regulator wire. on my alternator(not the powermaster, its out of an older chevy truck, it was free, took it to autozone and had em test it, it works) it has 1 and 2 stamped into the housing on the back of the alt, however it has a small 'r' and 'f' stamped as well, but they are the opposite as listed for the powermaster. anyone know of any way i can be sure which is which? and if i wire them up backwards, will i do any damage to my electrical system or ECU? im thinkin i should go by the stampings on the alt. that i have. any input appreciated
'94 X-Cab, EB inside and a few fabbed parts. My wife: "How about you stay on the road?" Me: "I drive a Toyota truck, the road is OPTIONAL!"
Re: GM alternator wiring? [Re: eastcoast] #731402 06/15/06 04:34 AM
kewlynx Offline
Check the schematics over at www.autozone.com for the Chevy.
I'd make danged sure about that before hookin' up; smoke checks can suck.
Hopefully Clay will chime in as well.
**ubi apis- ibi salus**
Re: GM alternator wiring? [Re: kewlynx] #731403 06/15/06 04:54 AM
E
well, after extensive digging in my car, i found the original alt plug that came out of the chevy with the alt i have, it seems to match the schematics for an 87...has one large wire, like 10ga, for the regulator connection(it calls the color of the wire 'rust', its kinda like an off-yellow color) and the thin brown wire is the field wire, so i think the markings on the alt i have are correct. ill find out once i get the new timing cover from engnbldr and get this motor back in the truck. thanks much for the schematics!
Re: GM alternator wiring? [Re: eastcoast] #731404 06/15/06 05:23 AM
OOP'S Offline
Here is how mine is wired. I bought a new plug for the GM altenator at NAPA.
Here is a thread on the install.
http://www.pirate4x4.com/forum/showthread.php?t=458156&highlight=OOP%27S
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: GM alternator wiring? [Re: OOP'S] #731405 06/15/06 04:52 PM
ErikB Offline
Toyota Moderator
#1 goes to the Toyota yellow "L" (light) wire,
#2 goes to the Toyota white "S" (sense) wire (the smaller white wire, not the big charge wire of course).
The Toyota red "IG" (ignition) wire is left unused.
I thought I had put that info in my PBB thread, but maybe not...
http://www.pirate4x4.com/forum/showthread.php?t=451359
http://home.4x4wire.com/erik
Re: GM alternator wiring? [Re: ErikB] #731406 06/16/06 12:48 AM
E
ok, but the problem i have is that the #1 wire, the field wire for everyone else, is the large rust colored wire in mine that has an 'r' stamped on the housing, like for the regulator, the one that loops back around to the charge terminal in http://www.rocketcityrockcrawlers.c...ner%20alternator%20Upgrade%20Project.pdf
the other thin yellow wire is terminal #2 and has 'f' stamped on the housing.
its the opposite of how everyone else has it hooked up. by the coloring of the wire, the way the pigtail matches the color that the schematics for the 87 chevy say, im guessing the one i have is wired in reverse from what all the other info says.
Re: GM alternator wiring? [Re: eastcoast] #731407 06/16/06 10:57 PM
ErikB Offline
Toyota Moderator
Like this, but also with an "f" stamped in?
So you are saying that on yours the rust colored wire goes from the #1 terminal to the big battery terminal?
Re: GM alternator wiring? [Re: ErikB] #731408 06/16/06 11:15 PM
ErikB Offline
Toyota Moderator
All the ones I've seen seem to match that rocketcity writeup and this Autozone diagram:
Re: GM alternator wiring? [Re: ErikB] #731409 06/17/06 03:09 AM
E
yeah, on mine the rust colored wire is much heavier guage and the #1 terminal has an 'R' stamped under it, the #2 has an 'F' stamped on it. also, mine isnt at the 12 o'clock position either. when i took it into autozone to have it tested, they wired it up with their universal connector to the test machine and it tested fine, which makes me think that i wire it like the rocketcity diagram says, however, the large wire and the stampings, plus the diagram i got from autozone that looked different makes me think otherwise. is there any way i can test to be sure which is which?
Re: GM alternator wiring? [Re: eastcoast] #731410 06/19/06 02:06 AM
E
ok, heres a pic...the wiring diagram seems to match this autozone diagram wiring diagram
heres a pic of my alternator:
web page
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6407 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-06-07 04:22:21 UTC
