My Montero won't communicate with me... #731462 06/15/06 04:08 PM
Y
yankee7809 Offline OP
I took my 95 LS in to get a miss diagnosed and the mechanic hooked the code reader thing up to her and couldn't get any thing at all.The truck's system would'nt read anything at all even though the check engine light is on.Any ideas?I have to run it without the over drive on and in power mode just to get some drivablity.So something is without doubt amiss(no pun intended!)
1995 Montero LS, KYBs, Michelin 31s. 2009 Kia Borrego EX. (Wife's wheels.)
Re: My Montero won't communicate with me... [Re: yankee7809] #731463 06/15/06 04:39 PM
Don't forget it's not OBD-II compatible. If she's using a mitsu compatible code reader then it should read something. If not, the ECU could be bad.
Re: My Montero won't communicate with me... [Re: yankee7809] #731464 06/15/06 04:45 PM
conner Offline
I would take it to another tech. Did he try to disconnect a sensor to see if the system can produce a code? Did he do a test to see what is causing the misfire? Is his scan tool any good? There are to many questions to provide an answer.
Conner
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: My Montero won't communicate with me... [Re: conner] #731465 06/15/06 07:00 PM
Y
Other than hooking up the code pulling unit no test was tried. the mechanic is trying to get a hold of the mitsubishi people here today for some advise and another fitting for her code puller.
Re: My Montero won't communicate with me... [Re: yankee7809] #731466 06/16/06 03:40 PM
[color:"purple"] [/color] her [color:"black"] [/color] code puller
This should be interesting. I've never heard of or met a competent female mechanic. No chauvinism here - just never found one...
Re: My Montero won't communicate with me... [Re: fasteddy] #731467 06/16/06 04:06 PM
stony-man Offline
what about the bubble-buttted blonde on that Trucks show? <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: My Montero won't communicate with me... [Re: stony-man] #731468 06/16/06 05:12 PM
W
Winston Offline
You can read the codes yourself on a 95 ls with a volt meter. I dont have the info with me, but you could probably find it on some Diamante forums. I have done it before. You just connect the clips to two pins on the obd connector and then read the meter sweeps like morse code. Some mitsu forum out there should be able to tell you which pins and the code translation.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: My Montero won't communicate with me... [Re: Winston] #731469 06/16/06 06:25 PM
conner Offline
If he wants to obtain the codes manually, he has to ground #1 terminal of the diagnostic connector and with the key on, the check engine lamp will flash codes.
Conner
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6224 MB (Peak: 0.7007 MB) Data Comp: Off Server Time: 2026-11-04 15:47:53 UTC
