HEI distributor wiring harness problems
#731541
06/15/06 08:59 PM
Got an HEI distributor on a 350. its on a boat, but lets pretend its in my jeep <img src="/forums/images/graemlins/wink.gif" alt="" /> the engine runs like crap, a noticable fuel or electric problem. While it was running I reach down to check the HEI wires that run from the cap into the distributor. As i touch them the engine gets worse. If i move them, the engine dies immediatly. The harness is cheap and doesnt fit tight into the cap. Is there an upgradeable harness, is this a common problem?
Thanks <img src="/forums/images/graemlins/scared.gif" alt="" />
86 CJ7, 258, MC2100 Carb, 4" Rough Country lift, 34" Swampers, Jeeperman bumper/tire carrier
Re: HEI distributor wiring harness problems
[Re: Thord]
#731542
06/15/06 11:27 PM
The harness should be almost water tight. Have you put some grunt into it! You may not have it all the way engaged. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5890 MB (Peak: 0.6369 MB) Data Comp: Off Server Time: 2026-05-26 04:52:30 UTCValid HTML 5 and Valid CSS
