replacement clutch hose #731614 06/16/06 04:55 AM
mhamari Offline OP
Im trying to find a replacement for the rubber clutch line on my 89 trooper. Id like to get a braided line but am having trouble finding them. Anyone have any ideas where to pick one up?
thanks
Mike Hamari
'89 Trooper
Re: replacement clutch hose [Re: mhamari] #731615 06/16/06 08:12 AM
CPOM Offline
1994 nissan 240sx rear brake hose is 8" long
front brake hose is 23.5"
both inverted flare female fittings m10x1.0mm
$15 at partsamerica.com
(advance autoparts, shucks , checker, kragen)
There's no real advantage with a stainless braided hose in this application. But if you feel like building it, you could buy some aeroquip braided teflon hose and m10x1.0mm ends. Or use any aftermarket front hose for toyotas (all use 2 female ends of the same size. (A braided isuzu line wont work as they use banjo fittings in the front and t-fitting in the rear.. )
CHRIS
98 Amigo, 92 Pup
Re: replacement clutch hose [Re: mhamari] #731616 06/16/06 08:20 AM
pucci Offline
take a look at this thread
2.6 Trooper
2.0 Impulse Turbo
Re: replacement clutch hose [Re: pucci] #731617 06/18/06 02:06 AM
mhamari Offline OP
Hey thanks for the replies, Im going crazy trying to bleed the air so I figure Ill just change everything and start fresh.
Mike Hamari
'89 Trooper
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6002 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-06-23 15:24:04 UTC
