Will an 86 bed bolt on to a 79 truck? #731621 06/16/06 05:34 AM
JimDandy Offline OP
The bed on my '79 truck is rusted out, and I could get the bed off of an '86. Does anyone know if it will just bolt on, or if more work will be necessary?
Re: Will an 86 bed bolt on to a 79 truck? [Re: JimDandy] #731622 06/16/06 06:21 AM
Jake97T Offline
I believe the front mounts will work, but youll have to get creative with the rear bed mounts...
Re: Will an 86 bed bolt on to a 79 truck? [Re: JimDandy] #731623 06/16/06 03:36 PM
mnwolftrack Offline
The mounts are the same from '79 to '95. What's different are the tail lights, license plate lights, gas doors, mud flaps and mounting brackets, and tailgates. Regarding the wiring, you may need to get the plugs and a short section of wiring from the donor truck. I can't remember if the tail lights from different years use the same plug or not, but that may be different and something to be aware of. Perhaps someone else can chime in about that.
You must swap a short bed for a short bed, or a long bed for a long bed though. A short bed will not fit on a long bed frame or vice-versa.
You will want to keep the tail lights, tail gate, fuel filler door, from the new bed. I even saw a Tacoma bed on an '84'-'88 style pickup yesterday. I didn't get to see it up close, but it may be possible that even Tacoma beds use the same mounting pattern.
Re: Will an 86 bed bolt on to a 79 truck? [Re: JimDandy] #731624 06/16/06 05:24 PM
fourwd1 Offline
Yeah, I have a 2nd gen 2WD bed on my 1st gen 4WD frame.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Will an 86 bed bolt on to a 79 truck? [Re: fourwd1] #731625 06/20/06 01:16 AM
ToYPU Offline
you dont want to deal with that send it to me ill take it off ur hands <img src="/forums/images/graemlins/wink.gif" alt="" />
kevin <img src="/forums/images/graemlins/evil.gif" alt="" />
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6047 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-05-29 15:25:56 UTC
