How do I remove this danged shift knob?! #731629 06/16/06 06:52 AM
Macdaddy4738 Offline OP
Im sure theres a trick to it...Im pretty sure its threaded on, but its not budging.
Any help guys? I drive a 98 TJ.
Re: How do I remove this danged shift knob?! [Re: Macdaddy4738] #731630 06/16/06 06:19 PM
I think you need to pry up the center cap on it (the deelly with the shift pattern) and there should be a nut there to remove.
Re: How do I remove this danged shift knob?! [Re: Macdaddy4738] #731631 06/16/06 07:05 PM
BigJim Offline
The older ones had a lock nut on the bottom that had to be loosened first before unscrewing the knob. But I think the one you have has the locking nut under the cap like sunder said.
Re: How do I remove this danged shift knob?! #731632 06/16/06 09:13 PM
Wow, Im not sure my cap can even come off anymore..
I thought it was one full piece with a pressure fitting.
Re: How do I remove this danged shift knob?! [Re: Macdaddy4738] #731633 06/19/06 03:53 AM
you have to pry up the cap on the stick - use a fine flat head screwdriver and work all around the cap to pry it up - it won't come up just by digging it in one side and prying like a crowbar -- after that its a nut to remove and the knob should pull off
Re: How do I remove this danged shift knob?! #731634 06/19/06 05:28 AM
okay thanks! I see the cap your talking about! Looks like someone pried it off before.
I ordered a new shift knob (8 ball...so cliche yet so cool) however, is backordered.
Re: How do I remove this danged shift knob?! [Re: Macdaddy4738] #731635 06/21/06 11:39 PM
CoronaJeeper Offline
I'll tell ya what's cliche, yet cool- the hula girl on my dash <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
'98 TJ, 4 cyl., auto
31" AT KO's on rockcrawlers,
custom bumpers, Hellas
2" Teraflex lift, no top,
no doors, no problem.
Re: How do I remove this danged shift knob?! [Re: Macdaddy4738] #731636 06/23/06 08:02 PM
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6119 MB (Peak: 0.6929 MB) Data Comp: Off Server Time: 2026-07-13 04:53:30 UTC
