AC Fuse blows #731832 06/17/06 01:46 PM
JoeAllen Offline OP
On Wednesday, my AC stopped working on my 94 Trooper on the way back from lunch. It's been working fine with no loss of cool all season, and never had a problem in the 2.5 years I've had the truck.
I checked the fuse and it was blown so I replaced it the next day. AC worked normally from the Auto parts store to the next stop, about 10 minutes or so, but blew almost immediately when I set out again.
I religiously shut off the AC a minute or so before I stop, and never start the truck with the AC on.
What should I look at next?
Thanks,
Joe
Re: AC Fuse blows [Re: JoeAllen] #731833 06/23/06 02:06 PM
JoeAllen Offline OP
Hopeful bump for the weekend...
Thanks,
Joe
Re: AC Fuse blows [Re: JoeAllen] #731834 06/23/06 11:21 PM
Troopersphere Offline
I no A/C expert for sure, but I might start by suspecting the compressor clutch???
Any unusual noises noticed ?
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: AC Fuse blows [Re: Troopersphere] #731835 06/24/06 05:15 PM
JLEMOND Offline
DO AS JEFF SUGGESTED , CHECK THE COMP , CLUTCH, TAKE A MIRROR AND A FLASHLITE AND CHECK THE CLUTCH DRIVE PLATE AND INSPET FOR A RUSTY DUST COLORED RESIDUE IN AND AROUND THE DRIVE PLATE THIS IS USUALY A GOOD INDICATION THE CLUTCH COIL IS LOOSING ITS HOLDING POWER AND LETTING THE PLATE SLIP A LITTLE AND THEN OVERHEATS AND SHORTS OUT, A COMMON PROB, ON A LOT OF COMP,, JERRY
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6007 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-07 03:50:28 UTC
